Updated:  10-June-2011
Powerchair Battery Types Voltage and Compatibility.
Thinking of using better more modern batteries in your Powerchair or scooter?
Detailed PowerChair ONLY Menu
Lithium Power!
I get emails daily and there's much talk on my Message Board about lithium battery power. On the face of it its easy. Just cough up some money and replace those awful heavy lead batteries. But there are a few things to be aware of.
1. There are three main types of lithium battery. And they all have different voltage and other issues when it comes to powerchairs. Our powerchair batteries are generally 24v (Nominal) and comprise of two lead acid, Gel or AGM batteries.
We need to match this voltage as closely as possible because Power Wheelchair controllers are very "safe" and will spot that something is different! They will then either refuse to work, or give annoying error messages (like over voltage) etc.  There's a chart below showing the exact voltages of each type of battery and you will be able to calculate the best match. The trouble is that every powerchair controller will respond differently here. You may have to take a gamble!
2. These "types" of lithium battery are all different electrically. Apart from voltages, some are very high resistance and so are useless with high currents we need. Some are excellent! Some are much more energy dense than others, and some are little better than the lead batteries we are trying to replace.
3. Some are "safe" in that on puncturing the case, or on overcharging they will not burn. Others explode or burn violently like a firework... Not good if they are under you in a powerchair.
4. Some are only available in small capacity cells, and so need making up into bigger packs. Some are available as large 50, 60, 80, 100 or bigger Ah cells.
5. Some can be charged fast.
6. ALL need either a battery management system, or a charger like the excellent Hyperion EOS1420i-NET3 charger that can balance cells as it charges.
7. Some are easily available, and some are only accessible in large quantities, and supply is sporadic. At least as of 2011 as I write this.
Type of Cell or Battery: Fully charged Voltage after standing until  stabilised: CC/CV Charge Voltage: Discharged Voltage (sensible minimum) Comments
AGM e.g. Odyssey &
Wet Lead Acid
Nominal Voltage 12v
12.8v
(6 cell battery)
25.6V
(2 batteries)
38.4v
(3 batteries)
1x
14.4v to 14.7v
2x
28.8v to 29.4v
3x
43.2v to 44.1v
1 battery
12v
2 batteries
24v
3 batteries
36v
This is what stock powerchair controllers "expect".
Voltages above Gel voltages may cause errors.
And in all cases including AGM batteries the battery meter will be reading incorrectly...
Gel e.g. MK as used by many powerchair manufacturers.
Nominal Voltage 12v
13.2v
(6 cell battery)
26.4V
(2 batteries)
39.6v
(3 batteries)
1x
14.1v to 14.4v
2x
28.2v to 28.8v
3x
42.3v to 43.2v
1 battery
12.2v
2 batteries
24.4v
3 batteries
36.6v
Lithium Ion Phosphate and other variants that are "safe".
Also called:
LiFePO4 cells.
Available as large Prismatic cells.
Nominal Voltage 3.3v or 3.2v
3.60v per cell
Charge & Charged voltages are almost the same Twice as energy dense as the Lead based batteries and half the weight.   Discharge down to 3v per cell.
3 cells = 10.80v
4 cells = 14.40v
7 cells = 26.60v
8 cells = 28.80v
9 cells = 32.40v
10
cells = 36.00v
11 cells = 39,60v
12 cells = 43.20v
13 cells = 45v approx as I am using HERE
Safe (don't usually burn) and are available as large prismatic cells.
Very suitable as powerchair batteries. Compatibility may be an issue, with warnings or errors on powerchair controllers.
Lithium Ion Polymer (LiPo)  that are NOT "safe"...
These burn or explode on any overcharge or cell puncture. Soft cases.
Nominal Voltage 3.7v per cell
4.20v per cell
Charge & Charged voltages are almost the same - Extremely energy dense, about 6 times as good as lead batteries. Discharge down to 3.5v per cell.
3 cells = 12.60v
4 cells = 16.80v
7 cells = 29.40v
8 cells = 33.60v
9 cells = 37.80v
10
cells = 42.00v
11 cells = 46.20v
12 cells = 50.40v
NOT Safe and would need to be in a fireproof container.
Very suitable as powerchair batteries otherwise with huge energy density.
Lithium Ion - as used in laptops, cameras, etc.
Nominal Voltage 3.6v per cell
4.10v per cell   Although SOME are charged at 4.2 like LIPO above.
Charge & Charged voltages are almost the same - Extremely energy dense, about 6 times as good as lead batteries. Discharge down to 3.4v per cell.
3 cells = 12.30v
4 cells = 16.40v
7 cells = 28.70v
8 cells = 32.80v
9 cells = 36.90v
10
cells = 41.00v
11 cells = 45.10v
12 cells = 49.20v
Usually used in cameras and laptops.
Good energy density, and less dangerous than LiPo batteries but expensive, high resistance and only available in small sizes. Still can explode or burn in some situations.
Nickel Cadmium
Nickel metal Hydride
1.27v, per cell and varies lots.  Any voltage depending on charge rate.  So charging has to be by series charge, with matched cells, and CC only.
Charging large packs therefore difficult and not efficient.
1.1v per cell Off load. Difficult to detect as they recover over time slowly. Not really suitable for powerchairs for many reasons.
Lithium Ion Batteries for Powerchairs and Scooters More here!
50v controller I use now here Roboteq Powerchair Controller
