Lightly used 4-wheel fat tire Urban Assault quad electric bike by Cycle QMX for sale. $2000. Located in California near Los Angeles.
This Urban Assault model comes with fat tires and rear suspension for a smooth ride and good traction. It has a 36 volt 1000 watt speed controller paired to an Ampflow A28 motor which gives it an average top speed of 15 mph. Front Disc brakes for superior stopping power and performance. The D-Cruiser handlebars makes this QMX cycle easy to ride and comfortable for all rides. It has a large aluminum basket on the back which make it equally capable shredding the trails or running trips to the grocery store. And the rear wheels are set back from the seat for easy transfers.
Specs:
4” wide 20” diameter fat tires
Top Speed: 15 mph
Color: International Orange
Brakes: Front Disc
Battery: 36 volt 12 Ah AGM battery
Controller: 1000 Watts
Rear Axle: Sun steel rear cage axle
Rear Shock: spring coil
Throttle: Twist-grip
Range: 9-40 Miles
Dimensions: 36" wide x 70” long x 35” high
Everything on this bike can be upgraded. Want more torque? Want reverse? Upgrade the electronics. You can even add a differential for more traction.
More Photos:
https://home.mycloud.com/action/share/d ... dad1f26ff6
