POWER WHEELCHAIR PROGRAMMER IMAX-02.VER2
Postby kopernik » 05 Feb 2022, 19:54
Programmer for setting up an electric wheelchair for yourself. You can adjust the forward speed (not all models can be increased), backward speed, sensitivity of joystick (with hand tremors).Before buying, ask questions and tell me the model of the electric wheelchair.
PROGRAMMING SOFTWARE can be downloaded after purchase from the link.
included:
-programmer
-PC connection cable
-connection and programming instructions
-software for programming
WORK for remote controls:
VSI
PILOT+
S-DRIVE
VR2
(does not work with R-NET remotes)
return of the purchase will be paid by the buyer. I ADVISE YOU TO CONTACT A SPECIALIST FOR PROGRAMMING.
I am not responsible for the breakdown of your electric wheelchair due to improper use.
Instructions for use:
• connect programmer by USB cable (included) to your computer with Windows 10 OS (best option) or Windows 7 (Mac OS is not supported). The computer will find a new device on its own and a new USB port should appear in the device Manager. If this did not pass automatically, then install the drivers
• install the software on your computer
• launch the software and configure it according to the instructions
• connect the programmer to your electric wheelchair (insert the XLC cable into the joystick connector).
• program connect to your wheelchair and you can start setting parameters.
NOTE: before programming, save your previously set settings to restore them if they are incorrectly configured
The driver need? And where to get
Windows 10 itself installs the driver from its base. For other versions, download the fresh driver from the FTDI site. The virtual COM port works by default.
SHIPPING FROM RUSSIA 20-24 DAY
price $90
free shipping
kopernik
Re: POWER WHEELCHAIR PROGRAMMER IMAX-02.VER2
Postby Burgerman » 05 Feb 2022, 23:11
We all have access to all software including OEM and factory here. Free. And we already have a member making up cables at a lower pice than that. But I will leave the post up.
