by slomobile » 20 Sep 2023, 17:17
It is super overcomplicated. It is dumb that I need to do this, but the ramp blocks access to the interior door handles. This is the case on every full sized commercial ramp based wheelchair transport as far as I know. In a fire or other emergency, we are trapped inside unless someone releases the door from the outside.
This kludge only solves the right door. There is still no solution for the left door, and I need that to work too. The left door handle is between the 2 rear doors and attached directly to the latch release body. That mechanism pulls 2 cables that in turn release a latch at the top and another at the bottom.
The video solution is needed because the door latch mechanism comes with the cables permanently attached. If a cable goes bad, we need to replace the entire latch/cable assembly. There is no swapping in a longer cable. I wish that were an option. Extending it via a device like this is the only option I am aware of. This problem exists for all the new crop of full sized ramp vans: Sprinter, Transit, and Promaster(Ducato)
This solution does not exist in the US as far as I have seen. This little UK shop appears to be the first place in the world to market a solution to this problem. Period. I called them trying to order one, but they simply will not ship internationally due to the bureaucratic hassles.
FWIW I know that at least one large van converter, MobilityWorks(Driverge) is interested in offering an automatic rear door solution but they have none. I've spoken with AMF bruns, Ram, Waldoch, and a handful of smaller converters/manufacturers. None have a solution.
