Programming leads
Re: Programming leads
Postby woodygb » 07 Aug 2022, 16:26
dieseldog wrote:Been a while since ive been on here but thank you for those links woody going to make a cable for the mothers new chair. Any links to the software would be greatly appreciated.
You have a private message.
Postby bob_viv » 11 Aug 2022, 10:20
Hi Woody, i purchased an s-drive programming cable from you a while back, which has served me well. I now need to program my latest scooter through the charging port. is it possible that you can give me the pinout for the charge port programming. i.e. connections on the four pin plug that i have go to which pins on the round charging port.
Thanks in advance,
Bob.
bob_viv
Postby woodygb » 11 Aug 2022, 10:25
Here you go ....
Are you certain that your new scooter uses an S-Drive?
Postby bob_viv » 11 Aug 2022, 14:21
Yes, for sure, cheers
Thanks a lot and best regards
Bob.
bob_viv
Postby DoctorFinlay » 20 Oct 2022, 14:53
I have a Sterling S700 scooter which I bought second hand. How would I go about purchasing leads to program the S Drive unit inside? Any info about software would also be greatly appreciated. Many thanks.
DoctorFinlay
Postby woodygb » 20 Oct 2022, 15:02
I can supply you with a lead or it is possible to construct one yourself.
Postby DoctorFinlay » 21 Oct 2022, 07:20
woodygb wrote:I can supply you with a lead or it is possible to construct one yourself.
If you could supply me with a lead that would be great, please let me know how much and how to pay. Thank you.
DoctorFinlay
Postby Jadams » 19 Jan 2023, 11:47
Hi Woody,
I bought one of your leads around June of 2021. worked perfectly for my S-Drive conversion on a Sterling diamond mobility scooter, I have recently bought a Drive sport rider with a Rhino2 controller, firstly, could the same lead be used to program? and secondly, I believe I would need the dynamics wizard software to do this, I know there is a "modified" version somewhere, does this negate the need for the dongle?
jeff.
Jadams
Postby woodygb » 19 Jan 2023, 12:15
Hi Jeff,
The S-drive lead is NOT compatible with the Rhino2.
The hacked Wizard software doesn't require a dongle.
Postby Jadams » 20 Jan 2023, 12:14
Hi Woody,
Thanks, is it possible to make up the leads and obtain the software?
the delay when starting and acceleration is so poor, it's embarrassing when someone lets you cross and looks like you're taking the mick.
jeff.
Jadams
Postby Jadams » 20 Jan 2023, 12:42
I already have USB to serial adapters and a true COM port available.
jeff
Jadams
Postby woodygb » 20 Jan 2023, 13:07
The parts that you already have will not help.
I can however make you an interface that will do both the S-Drive ( plus VR2 , Vsi ,Pilot+ , Egris and SOLO ) and the Dynamic Rhino2 / Shark...A switch is used to select which make either PGDT or Dynamic .
Postby Jadams » 20 Jan 2023, 16:55
What's the cost Please
jeff
Jadams
Postby woodygb » 20 Jan 2023, 18:09
£35 incl postage ...payment once I have one made.
It will however take me a little time to complete one as I do not think that I have all the parts kicking around, so I may need to order some.
Postby Jadams » 20 Jan 2023, 19:22
Perfect Woody,
Can we do that then please?
Jeff
Jadams
Postby woodygb » 20 Jan 2023, 20:20
:thumbup:
Postby woodygb » 27 Jan 2023, 00:03
Jadams wrote:Perfect Woody,
Jeff
Jeff , I have one ready for you.
Postby DonQuixoteDeLaManche » 21 Apr 2023, 09:43
Hello Woody,
I have a very old Roma Sirocco and an even older Pride PD11, both of which are amazingly still working well after all these years!
Both wheelchairs use the same PG Drives Controller.
I made a USB>Molex programming cable many years ago from a diagram you published and that was fine, but unfortunately it has been misplaced and lost.
I no longer have the ability to manufacture another owing to my disabilities and I would be deeply grateful if I was able to purchase a replacement from you.
I am not worried about the cost and can pay you by Direct Bank Transfer or by PayPal as you so prefer.
I still hold the PG Drives software (SK76982/7).
Regards, Simon.
Don Quixote De La Manche
(La Manche ~ The English Channel :-)
Postby Burgerman » 21 Apr 2023, 11:06
You might PM him.
Users browsing this forum: No registered users and 5 guests
