Page 4 of 9
Re: Programming leads
Posted:
17 Sep 2018, 10:43
by woodygb
Your P.M.'s went thru fine....I just wasn't around to reply to them.
Posted:
21 Sep 2018, 16:59
by calabash
A big thank you woody, worked like a dream and now it drives........
Posted:
21 Sep 2018, 17:14
by woodygb
Your welcome.
Posted:
08 Apr 2019, 16:33
by dieseldog
Do we have any knowledge of someone who can supply the rnet dongles yet
have had a cable of you woody for a few years now but converting the chair to r net.
Posted:
08 Apr 2019, 16:48
by woodygb
Nope ...you need to purchase a genuine one.
Posted:
20 Apr 2019, 04:24
by Smitty62
Woodygb,i am interested in purchasing a programming cable for my jazzy 1100 with a pg-drive pilot-d49637 70amp controller
can you build one for me? if so can pay with paypal
let me know total cost with shipping to;
HC1 Box304h
Fairdealing MO. zip code: 63939 USA
This is a physical home address, not a po. box
Much appreciated, Michael Smith
Posted:
20 Apr 2019, 10:31
by woodygb
Hi Michael,
Whilst I can supply a lead for the OLD Pilot , the software that is available will not program it.....the software will simply say "Pilot" on the very bottom line of the screen but gives no programming options.
Personally I would swap it out for a later VSi.
Cheers Woody
Posted:
20 Apr 2019, 14:46
by Smitty62
Thank you.
I will locate one
Posted:
10 May 2019, 16:36
by Dan
Woody are you selling the bluetooth boards for the PL8 charger?
Posted:
10 May 2019, 17:56
He sold me mine.
Watch the vid of it in action while doing a quick vid yesterday.
I actually got 3. Only one fitted so far, but will get to it soon. Works like a charm. Cant manage without now as its just easy and seamless.
Laptop on bed in bedroom monitoring, and controlling. Powerchair (salsa) in the kitchen. Typical example of BT as I use it regularly testing batts or charging spare backup chairs etc. As here.
http://www.wheelchairdriver.com/gopro/current-state.mp4
Posted:
10 May 2019, 18:15
by woodygb
Dan wrote:Woody are you selling the bluetooth boards for the PL8 charger?
I can supply a board programmed to suit with the correct diode and some leads ... NOTE :- It's not plug and play so you will need to fit it internally / externally to the PL8.
Posted:
10 May 2019, 19:26
by expresso
Hi Woody - i may be interesting in one also - may give it a try - would you have or can supply instructions on how to do it - internally and externally ? pictures would be excellent
Posted:
10 May 2019, 19:32
When I do the next one, I will do a set of pics and instructions. But really, its easy. And kind of self explanitory.
The low drop diode, is essential though. The simple signal diode works only if you dont charge at high power.
A couple of simple filter caps, may or may not be needed. I fitted them anyway. And its a bomb proof setup. Just works.
Once you do it, messing about having to plug it into a computer and being limited to length of USB wire etc is all a pain and not needed. You cant go back!
Posted:
10 May 2019, 19:38
by expresso
Ok i will be on the look out for your Pics and step by step - Will purchase from Woody and follow your instructions - if all goes well - i will do my others also - i run a few Pl8s at a time during the summer high usage and have wires all over the place - it works - but would be nice without that one wire also
now this can also be used with the Cable down the line if needed once its done wireless ?
Posted:
10 May 2019, 19:48
by woodygb
IF your having more than one remind me to program them as PL8A ,B ,C etc... or some identifying word/s to help distinguish between each..
Posted:
10 May 2019, 19:49
Yes. The way mine are done leaves a 3 pin connector hanging out of the rear, plugged into the same place the FUIM3 normally fits. So you just unplug that, and connect the FUIM3 instead.
But I dont think you will ever need do that. Maybe only for secure firmware updates. I would probably risk the BT though...
Posted:
10 May 2019, 21:27
by expresso
woodygb wrote:IF your having more than one remind me to program them as PL8A ,B ,C etc... or some identifying word/s to help distinguish between each..
yes very good thanks - i will PM you in a while about it etc,
Posted:
11 May 2019, 06:39
Warning. Not sure that the last 2 you programmed are working. Very fast test yesterday. The name change may make them not work... Spaces? More than 8 letters? Or it may have been something else. Will test them again soon.
Posted:
17 Jul 2019, 12:25
by Mkay
Hello woody, I just wanted to let you know I have dropped you an NG email ordering a lead to the orange address. Incase its not one you monitor. Cheers
Posted:
17 Jul 2019, 17:02
by woodygb
Mkay wrote:Hello woody, I just wanted to let you know I have dropped you an NG email ordering a lead to the orange address. Incase its not one you monitor. Cheers
The orange email is DEAD...has been for a few years.
use nala_doow ( at) hotmail (dot) com
Posted:
22 Aug 2019, 21:18
by Porkchops
Hi would anyone be able to make a curtis 1314-4401 cable or know where to get one at a decent price
Posted:
22 Aug 2019, 21:48
by woodygb
Posted:
23 Aug 2019, 13:10
by Porkchops
Posted:
23 Aug 2019, 13:42
by Porkchops
Or if possible I was wondering if you make any of them and if so I'll be happy to purchase one from you
Posted:
23 Aug 2019, 16:21
by woodygb
I will happily make one for you ...what are you trying to connect to?
Posted:
23 Aug 2019, 17:26
by Porkchops
I want to connect to a scooter controller a 1212 I believe it is
Posted:
23 Aug 2019, 17:30
by Porkchops
On second thoughts I'd like to try and make a cable first if I have any problems I'd get you to do me one if that's ok.
Is the cable I've linked ok to order ?
Dont mean to mess you around
Posted:
23 Aug 2019, 17:59
by woodygb
Yes ...that cable is fine ..you'll also need a mini molex.
I usually use something like this as the donor for the molex.
https://www.ebay.co.uk/p/4-Pin-Molex-to ... 0888&rt=ncFTPProg is used to INVERT the RX and TX signals..
Posted:
23 Aug 2019, 18:15
by Porkchops
Ok sounds good going to order that now. Is there some sort of guide to program the cable and also a link to the appropriate software?
Posted:
23 Aug 2019, 18:20
by woodygb
http://www.nocoev.com/curtis/Software%201314-4401/Guide ...Ummm not really ...run FTProg and INVERT the RX and TX.
