Wanted - Tilt actuator Puma 40
Postby elryko1992 » 29 Mar 2018, 22:39
If someone have to buy or can help me where can i found a Tilt actuator, because i have only the Lift Actuator, and i need the Tilt Actuator for Puma 40. Thanks!
Link with Tilt Actuator PDF: https://drive.google.com/open?id=1vA_ol ... GOWch0K8aA
Link photo1: https://drive.google.com/open?id=1kxIW2 ... g2zaWkrv2S
Link photo2: https://drive.google.com/open?id=1R8YDU ... YpYeiLTB1k
elryko1992
Re: Wanted - Tilt actuator Puma 40
Postby elryko1992 » 04 Apr 2018, 16:33
Part number: 1017466 - with 2 switch
elryko1992
Postby Burgerman » 04 Apr 2018, 18:24
Salsa or Jive one should also fit I think.
Postby elryko1992 » 04 Apr 2018, 20:12
Burgerman wrote:Salsa or Jive one should also fit I think.
where can i find? I want to buy it, give me a link or something.
elryko1992
Postby Burgerman » 05 Apr 2018, 00:23
Ebay, be patient! They turn up, you need the right one. Maybe the whole tilt / lift mechanism. But those are expensive.
You may have no choice but to buy new. Or remove it, read the data, part numbers, dimensions, and the newtons, speed, etc and search online. You can likely buy half the cost from an actuator supplier or get an equivelent. But cheap they are not.
Whats wrong with it? Did you test, remove cover, and take a good look?
This place is not cheap. https://www.servocity.com/motors-actuat ... -actuators
But you should find an equivelent even if it looks different. Yourse is a linak one, those are sold by industrial suppliers.
Postby elryko1992 » 05 Apr 2018, 07:21
Burgerman wrote:Ebay, be patient! They turn up, you need the right one. Maybe the whole tilt / lift mechanism. But those are expensive.
When i buy the chair was like brand new and i have only the lift actuator, and the place is empty for tilt, and i need the tilt because is good for me, the lift i don't use much, the tilt i need from REAC, i speak with Sunrise Medical and is the part number: 1017466 - with 2 switch, because is after 2012. Main is from 2014. I think the tilt, is the same like your R2 Salsa, if you want to tell me the size from your tilt, would be great. i don't need the whole mechanism.
elryko1992
Users browsing this forum: No registered users and 26 guests
