stefanturbo wrote:I am looking for a actuator switch box. Because i'dont have a Permobil or Quickie wheelchair it is dificult to find a universal actuator switch box that works with the generic Rnet software.
Irving wrote:stefanturbo wrote:I am looking for a actuator switch box. Because i'dont have a Permobil or Quickie wheelchair it is dificult to find a universal actuator switch box that works with the generic Rnet software.
What do you mean by an actuator switch box? Please explain what you are trying to do.
Normally, actuators are driven from an R-Net ISM. You can connect 5 switches to an R-Net Omni controller, or 2 external 'buddy' switches to a standard JSM, and then link these to the actuators in programming.
If you mean to control the actuators independently of R-Net this can be done, but will be a custom build.
stefanturbo wrote:Irving wrote:stefanturbo wrote:I am looking for a actuator switch box. Because i'dont have a Permobil or Quickie wheelchair it is dificult to find a universal actuator switch box that works with the generic Rnet software.
I need a solution to change the position of the backrest actuator and the tilt actuator. I have a CJSM2 as attendant control but I want to have a fast way to adjust these actuator instead to have A attendant to use CJSM2 i want to change it with buttons. I have looked in the Rnet software but i cant find parameters to setup it.
