Right hand swing away control mount for Sunrise Medical quickie Jive m2/ Puma 40 Seder ergo . Sunrise Medical eparts #21809060-002
Burgerman wrote:Word of warning. Those swing aways are rubbish. The joystick is all wobbly, and it makes real control once programmed impossible. I use one. But I redrlled it for the next size up screws, and carefully reamed each hole for a stiff friction fit. And used fibre washers etc to fine tune things. Now it works like it should have to begin with. I also made longer "fingers" while I was at it. Because once mounted / relocated INSIDE the arm, where it needs to be for proper comfort, and hand technique, its too short to swing away and miss the arm tops. Even more so if you have the nice wide jay P shaped custom arm tops as I do.
This stuff is so basic, you would think that the manufacturers could make a decent swing away that works without being rebuilt, and isnt loose and wobbly wouldnt you, or that was mounted correctly and in the right place, or that was actually long enough to work! You will also need to lift the thing up tight below the arm top, as well as making a spacer to raise the control pod high enough to have proper hand technique. This is a bit of fine tuning that will take all day to sort out properly. That you shouldnt have to do!
See the pic here:
rover220 wrote:Burgerman wrote:Word of warning. Those swing aways are rubbish. The joystick is all wobbly, and it makes real control once programmed impossible. I use one. But I redrlled it for the next size up screws, and carefully reamed each hole for a stiff friction fit. And used fibre washers etc to fine tune things. Now it works like it should have to begin with. I also made longer "fingers" while I was at it. Because once mounted / relocated INSIDE the arm, where it needs to be for proper comfort, and hand technique, its too short to swing away and miss the arm tops. Even more so if you have the nice wide jay P shaped custom arm tops as I do.
See the pic here:
completely different swing away to what the salsa uses.
Irving wrote:google drive links need permission, and you can't use with BB [img] tag, that needs a jpg, etc file extension.
optical10 wrote:Ok thanks for the heads-up on the mods needed.
Joysticks on the two donar chairs used for hybrid got your reposition treatment, much better. Managed to gain height by turning the T shaped mounting bracket upside down and insertimg it into the reverse side of the armrest which also is inside out inbound!
optical10 wrote:rover220 wrote:Burgerman wrote:Word of warning. Those swing aways are rubbish. The joystick is all wobbly, and it makes real control once programmed impossible. I use one. But I redrlled it for the next size up screws, and carefully reamed each hole for a stiff friction fit. And used fibre washers etc to fine tune things. Now it works like it should have to begin with. I also made longer "fingers" while I was at it. Because once mounted / relocated INSIDE the arm, where it needs to be for proper comfort, and hand technique, its too short to swing away and miss the arm tops. Even more so if you have the nice wide jay P shaped custom arm tops as I do.
See the pic here:
Yep your right but im using the Jive m2 sedeo ergo R-net joystick'd seat on the Salsa r2 chassis, which uses the right mount fittings to take this requested swing away.
Users browsing this forum: No registered users and 57 guests
