Tilt/Recline Joystick is backwards
Postby hobie1dog » 16 May 2018, 00:32
On my Quickie 636, the operation of the joystick Is opposite of how it should intuitively work. If you want to tilt back, you have to push the joystick forward. Pulling back on the joystick lowers you back down. When I questioned the two people who "setup" the chair about it, they said that's the way it has always been. Can it be changed in the programming?
Invacare M61
hobie1dog
Re: Tilt/Recline Joystick is backwards
Postby Burgerman » 16 May 2018, 00:33
Postby hotwheels_75 » 16 May 2018, 15:24
You can change it to whatever you want in the programming, depending on your personal preference or physical ability.
On both my Pilot+ Project chair and my MK6i controller on my Arrow Storm I have it programmed to push forward for both tilt back and tilt forward. It switches direction each time I push it forward. You can set it to any joystick direction combination you want. Forward, back, left or right.
hotwheels_75
Postby hobie1dog » 16 May 2018, 21:41
I'll have to round up a proper cable, find the software to use on a PC, and then correct it. So frustrating not having a dealer worth a sh;t. The salesman had the personality of a retarded snail.
Invacare M61
hobie1dog
Postby rover220 » 17 May 2018, 06:09
hobie1dog wrote:I'll have to round up a proper cable, find the software to use on a PC, and then correct it. So frustrating not having a dealer worth a sh;t. The salesman had the personality of a retarded snail.
just swap the wires round
Users browsing this forum: hotwheels_75, tnt, woodygb and 31 guests
