JoeP wrote:Hi ex-Goowsrider,
I used to build houses and I've always been interested in 'best practices'. Somewhere I ran across your comments about military spec & crimping and that stuck in my head. I also used to be something of a tool junkie, but nowadays I'm lucky to be able to use a can opener.
In know its no Thomas & Betts, but would Powerwerx's $89.99 Hand Held Crimper qualify as a good crimper for SB50s?
https://powerwerx.com/anderson-sb-connectors-sb50-50ampJoeP
I use the PowerWerx crimper on the 15/30/45 size Andersons. I have a hydraulic unit I use on the SB-50 / PP-75 size, even though I also have the dies for the SB-50 pins as part of the crimper kit. PowerWerx CLAIMS that their crimper is approved by Anderson for use on those pins,
The Anderson documentation on assembly says to crimp OR solder, with soldering recommended for solid or minimal stranding wire (i.e. house-wiring style, as opposed to the marine or welding cable that we use) They don't mention the PowerWerx crimper, but the description of the manual crimper style is consistent with the PowerWerx unit...
What is interesting is that the hydraulic units that most of us are using on the SB-50's do a hexagonal crimp that basically squeezes the wire all the way around. However the description of the Anderson recommended tools are ALL for 'indentation' style where they crimp by denting the pin barrel rather than squeezing it, which I suspect might be more structurally sound. They also call out the use of a 'reducer sleeve' if using smaller than AWG-6 / 10mm^2 wire, AND cable clamps (note what I said earlier about strain relief, so that stress is NOT placed directly on the crimp...)
I currently crimp and solder the SB-50's but crimp only on the smaller sizes, and most other crimps. I may experiment with crimping only on my next builds...
