Postby elryko1992 » 04 Dec 2017, 23:37
elryko1992
Postby Burgerman » 06 Dec 2017, 18:12
Couldnt get the Duro tyres, out of stock... So now have a similar construction, 120/70-8 tubeless set of these. Thats same 14.3 diameter, 5 inches wide, 4 ply, tubeless and so very stiff/strong construction and so no worries about punctures and long service life:
Postby hank » 06 Dec 2017, 18:14
Nice tyre :clap
at least you can buy fronts same make to match :dance
Postby Burgerman » 06 Dec 2017, 18:25
On a pair of these wide 8 x 3.5 inch tubeless alloy rims. I bought 4 of them, at about £10 each via Shirley.
Where do I get matching fronts again? :cussing
Postby hank » 06 Dec 2017, 18:32
Postby Burgerman » 06 Dec 2017, 19:13
Ordered :thumbup:
Postby Burgerman » 06 Dec 2017, 19:15
Now I got the stupid wheel adapter/spacer thing to make again! hanged
And lithium all over... And a back/headrest.
And make smaller footplate.
And 1000 bolts to swap for stainless, and then find matching front casters!
Postby hank » 06 Dec 2017, 19:30
I wonder if groove Amt hubs are same fitting. If so you have a hole centre to work with
If you mean alloy castor forks use groove ones. Like on my groove/brushless
Postby hank » 06 Dec 2017, 20:42
hank wrote:I wonder if groove Amt hubs are same fitting. If so you have a hole centre to work with
Castor wheels. trampaboards.com
Postby shirley_hkg » 07 Dec 2017, 02:45
Burgerman wrote:On a pair of these wide 8 x 3.5 inch tubeless alloy rims. I bought 4 of them, at about £10 each via Shirley.
YOU may love these mud guards . cheers
Postby Burgerman » 07 Dec 2017, 02:58
Err... No! Black!
Postby shirley_hkg » 07 Dec 2017, 03:10
Someone is using this tubeless as front .
Postby Burgerman » 07 Dec 2017, 04:14
Too big, too skinny, too hard, and non symetrical. I am not changing front... :cussing
Well not yet! :fencing
Postby hank » 07 Dec 2017, 10:16
Burgerman wrote:Ordered :thumbup:
Had some tubes off him right money as well. ;)
https://www.ebay.co.uk/itm/Heidenau-Inn ... SwCU1YxXEx
Postby Burgerman » 19 Dec 2017, 03:16
Today 19/dec/2017, I paid for my new lift/tilt/recline/power centre footrest/black/r-net 120 with advanced colour joystick powerchair! Its not very urgent, and only for occasional/intermittent usage. In the meantime I am still trying to fix a sore on my cocxcxcxcxc or however its spelled! :fencing
Cant say how much or where from unfortunately, or I would have to kill you... :shifty: But the price was very good! :thumbup:
Should be here about 22nd. Ish. Then wheels/tyres/programming/seat relocated and a lot of general tidying up. As usual. Like smaller footplate, replace most of the bolts with better/grease, replace sling back with something other. And lithium as long as it all works well till the spring.
Postby elryko1992 » 19 Dec 2017, 14:15
I really wait to see your new powerchair 8-) :thumbup:
elryko1992
Postby Scooterman » 28 Dec 2017, 08:58
They'd bug me cos they've got the union jack/flag wrong (check out BM's logo for correct flag).
Postby LROBBINS » 28 Dec 2017, 10:01
Can someone lead me to a link to these? Are they available in 3.75 inch? Would Carlisle Turf Saver 4.80 - 8 that call for 3.75 rims be too pinched on 3.5"?
Postby Burgerman » 28 Dec 2017, 11:26
I think only 3.5. PM shirley!
Proper tubeless rims. Well made. Cheap from HK. Too pinched? A little pinched I would say.
Postby shirley_hkg » 01 Jan 2018, 10:57
Strange features with new OTTOBOCK JUVO . . :ak47 :bounce
Postby Burgerman » 01 Jan 2018, 12:14
Summary?
They fit a gyro so that front drive becomes possible (but still steers odly) and on other chairs when you attempt to steer stupidly programmed powerchair in a straight line you dont suffer the delayed action over controlled swerving about. Personally I hate driving with gyro on, and couldnt disable it fast enough. Its not required if you have normal hand function and coordination with a properly programmed chair. It just removes feel and makes things worse.
They test with some added weight... Really.
They have fold back casters on front drive...
They programmed in a load of damping so cobbles dont cause your shaken hand to change direction. Which means it steers about 3 seconds after you tell it. Real solution is proper joystick hand/finger placement and position.
They have caster locks. Those are really not new. They have been available for years. I wouldnt want them, they are not required on a properly programmed chair as it goes exactly where its told anyway...
They have programmed in some speed reduction that automatically slows the chair (which I really dont want!!!) if you are going fast and try and turn. That is possibly useful on a front drive (unstable platform) powerchair.
In other words a load of band aids to try to cure the symptoms that are actually caused by low turn acc/dec settings.
Postby Burgerman » 16 Jan 2018, 20:36
Right. Delivery on 19th jan. Ordered 20th dec. So thats errrr, :cussing almost a month! Thats slow. But to be fair it includes xmas, new year as well and the germans dont work at xmas and new year :fencing
And it a mix of parts, and black paint, so a "build for me" option or 3 too. So I will excuse them. And the price was very good!
Now I have to rebuild it and chop off all the unwanted bits, narrow its single power footplate, move the lights inboard, reconfigure arms, reprogram it, swap its skinny wheels and tyres, batteries, seating position, joystick position, seat back replace, add the IOM and RC and external charge connections and vehicle tie down bolt... And test!
If its any good I might get a spare. Or a V4.
czy banghead urinal
Postby hank » 16 Jan 2018, 22:39
That will keep you busy for a while :dance :dance :thumbup:
Postby hank » 19 Jan 2018, 17:54
Your new chair arrived yet John ;)
Postby Burgerman » 19 Jan 2018, 17:57
No. Just called sunrise med and they said date for delivery means "shipped". From germany! So can actually arrive any day next week :cussing :worship
Postby hank » 19 Jan 2018, 19:46
Think you can manage with waiting
Don’t think your stuck for chairs
Good luck nxt week
Postby hank » 19 Jan 2018, 19:57
Good luck nxt week
Postby hank » 19 Jan 2018, 20:42
:dance :dance :dance Good luck next week[/quote]
Postby Burgerman » 23 Jan 2018, 14:46
Theres a large pallet in my hallway. From germany.
Postby elryko1992 » 23 Jan 2018, 14:48
I waiting to see your beauty :D
elryko1992
Users browsing this forum: Jay_x, shirley_hkg and 99 guests
