Re: PGDT interface update
Postby malamar » 04 Jul 2012, 17:41
nops... i tried to say that the refurbishing done recently by you to the main site has been an happy and very exitous one:
greetins. Its like reading all of it first time!
On the programming side im still in the dark : nothing seems to work with my W7-32 bits and already resigned to learn to drive deiayed, you get used finally, as millions of other powerchairs users...Difficult to beat the Safety System from a partigiani free lance sharp shooter corner ... oh bella ciao, ciao, ciao
malamar
Postby butchec » 04 Jul 2012, 19:28
Hi.
Malamar, in regards to programming. I am using windows 7 32bit on a HP laptop.
The software crashes one on 10 times of loading and running compatibility wizard makes no difference to it.
I am using the kenwood lead with a good xlr connector matching woody wiring image.
If the crashing gets too bad I uninstall/reinstall the software.
The drivers for the USB are direct from windows update, not the ones you download in the forum.
I did find however that it doesn't work in the USB port on the left side of the laptop (dual ports) but works fine on the right (single port)
Cheers. Chris
butchec
Postby woodygb » 04 Jul 2012, 19:49
Interesting ...have you tried JUST the drivers on the disk and NOT the Windoze updates?
Postby Burgerman » 04 Jul 2012, 21:23
On 64 bit, with ONLY the driver on the disk, it is extremely solid. On my server/workstation and laptop.
In device manager, delete the device, and tick the box where it says "delete driver?" Then click OK.
Then unplug the USB connector, plug back in, and DONT LET IT install from the web. (turn off auto device driver updating, disconnect from the web) If it installs any drivers at all, then delete the device, and driver, again. Rinse and repeat until it cannot find a driver...
Reboot, install the one on the disk only.
CHECK it ONLY has the correct driver installed. Change to a port 1 to 8.
Now try.
Postby malamar » 04 Jul 2012, 22:21
Better i don`t post nothing today: i'll not be too happy later on....
Chris, so much thanks for imput!
malamar
Postby popschief » 05 Jul 2012, 01:59
A physicist friend loaned me an external drive loaded with a bunch of movies and it has two USB male plugs. He said it may need to have both of them connected to make the drive run. I wonder if it's something to do with something like that? Just a thought.
bp. :idea:
popschief
Postby Burgerman » 05 Jul 2012, 02:15
because the 2nd one may be needed to give enough power to spin up a disk. USB alone may not have enough. And they vary. But all should have plenty for the lead.
Postby malamar » 05 Jul 2012, 08:11
Last version of Photoshop I purchased for a small fortune, the CS5, just ran only 32 bits (don`t know today) so I'm unwilling to switch to 64 Bit and risk to invalidate my favorite sofware or have to buy a new one to very little use, today...
Seems that Woody hard worked perfectly on W-XP ,but it is no longer a Microsoft supported OS and generally hard to get and beware of XP3...So the same old story of makers wanting to sell new products every year and forcing us to do so and buy, even if the extant is still a perfectly valid one. This programming thing is not wanted at large ultimately, and just available to somebody who lives somewhere and tells more funny jokes, apparently...so good for Sunrise etc.
malamar
Postby woodygb » 05 Jul 2012, 09:47
Malamar ...I haven't forgotten your predicament.
I will ... assuming that I get some expected funds tommorrow .. be upgrading to Win 7.... I can then test programming leads ( not just the Pilot ) with the common Windows 7 O.S.
I'm also considering ordering the genuine lead online as the PGDT ordering system accepts my REAL address and postcode ..but not the Country ... ie UK. ... our GPO postal system should sort out the wrongly addressed package fairly easily if I use the I.O.M or Jersey as my country.
Cheers Woody
Postby Burgerman » 05 Jul 2012, 11:18
Woody I forgot your disk...
Do you still need win7 64?
Postby woodygb » 05 Jul 2012, 11:27
John,
Cheers for the offer ...I may take you up on it ... it all depends on the deal ( with / without O.S. etc ) that I can get when purchasing a new puter.
Postby malamar » 05 Jul 2012, 12:08
Woody, you know that you are my man into the knows for anything puter, electric, electronic wise; i can only "plug % play" I'm also considering retiring my battered portable puter for one offered as most with W-7 64 BITS AS MOST COME WITH NOW.
Will hear from you when news arise.
Cheers
malamar
Postby Burgerman » 05 Jul 2012, 13:32
Likewise I now have a user freindly copy of 32/64bit Photoshop CS6. (But you need to be a bit computer savvy to install it).
Most software is like this...
Isohunt, pirate bay, Minova, many others, newsgroups, etc are your freind... Everything is available.
Postby malamar » 05 Jul 2012, 17:10
WE MUST LIVE IN DIFFERENT TIMESPANS, jOHN....
What is a solid reality for you, it's a Christmas tale for me: should i only try to install a cracked photoshop copy, 'puter will "tell" Adobe and a strange general collapse of my system will follllow: don`t ask me how i know. I know too there are ways around it, but for people in the know, who I`m surely not, or any longer.... As an example i talked with local quickie rep for an extimate of the "tuning" you suggested for my chair and he politely insinuated i should have my head checked and why i ever would do that, practically the same batteries i have now, same motors, inferior but by just so little controller...all my madness, sadly, and force my community to install me a chair lift, poor deluded !...
must join guerrilla again!
malamar
Postby Burgerman » 05 Jul 2012, 19:10
Its THEM that need their heads checked.
I go up a REAL 14+ degree slope, with difficult transition, really easily, using about 1/3rd of a stick of control in a chair modified in exactly the way I describe. Might not sound a lot but I am very heavy...
Yet a stock F55 chair, with 80 amp controller, stock programming, stick cables, 73Ah MK gel batteries, will not even get onto the ramp. It jams up as the casters leave the deck, or as they twist sideways onto the ramp, and the chair is stuck. You can get it to go up ONCE ON the ramp, but its slow, and needs full power. And forget about steering! Go straight or stop.
The NORMALS in society dont ever really grasp anything. The same mods make JoeC's wifes powerchair perform much better at sport.
Postby hotwheels_75 » 07 Aug 2012, 16:39
No sure if I overlooked it, is there extra software required in order to reprogram a chair controller using these cables & drivers?
hotwheels_75
Postby woodygb » 07 Aug 2012, 16:41
You need the higher level P&G PC Programming software.
Also note that the USB lead is only tested and working with the PILOT + controller.
Postby hotwheels_75 » 07 Aug 2012, 16:57
I thought so. Is it easily acquired somewhere? I've not been able to find it. I have the Pilot+
hotwheels_75
Postby woodygb » 05 Sep 2012, 22:28
Driver Version 3.2.0.0 wIN 7
ser2pl64.zip
(40.53 KiB) Downloaded 1052 times
Postby woodygb » 06 Sep 2012, 18:59
Seems the above needs extra files appended to it ..Vista/WIN 7
ser2pl.inf_amd64_neutral_ac682fd4be9fc86a.zip
(49.86 KiB) Downloaded 1062 times
Postby Burgerman » 06 Sep 2012, 19:53
That driver is supplied with the lead. On a disk. And it works!
Postby woodygb » 06 Sep 2012, 20:07
Ashley is having trouble with lead and disc supplied...Windows is giving a code 10 ..device not working error.
So ..trying to help via the board ..we've now made contact via email.
Postby Burgerman » 06 Sep 2012, 22:59
Check that the correct driver is actually loaded, in device dam=ager. Usually not. And check ALL com ports and USB sockets, not all are equal.
Postby malamar » 07 Sep 2012, 08:51
All trouble seems to start with W7 32 bits; Bm has W64 bits and not heard him crying yet....thinking of buying new simple laptop with W64 Home premium for these affairs only: life is too short even if expensive.....
malamar
Postby Burgerman » 07 Sep 2012, 10:19
Yes all win7 64 here. 3 PCs. Fiddly to make work but once working foolproof. Almost every combination of serial port number, and the right driver (the one supplied) and making sure that windows is actually USING it, worked in all cases.
Postby woodygb » 13 Sep 2012, 15:37
Just for reference..Ashleys is now working Windows 7 32bit, using driver version 2.0.0.24
Malamar ..I finally have a NEW genuine lead and adaptor for you should you wish it.
and finally ...more info ..the homebrew lead will NOT connect with scooter controllers.
Postby malamar » 15 Sep 2012, 10:32
YABADABADU got this in the mail early this morning; "sent along genuine pod earlier": i expect disaster chain while getting the knack to it, but progressing at last, damn moonrise !!
malamar
Postby malamar » 19 Sep 2012, 18:35
red in face,humiliated to near suicide, i find no way that my more than incipient alzheimer or similar allows me to install programming dongle,original or less:what a shame!!! but head bursting in flame Woody,if you agree i thought to send my tabletop to your uk home to install it for me i You then bill me accordingly ,but i need someone's hand or must give up in defeat and desperation.Tell me about your answer here in this thread cause i can't neither see no private message being message filled up
I`ll be gratefull
malamar
Postby woodygb » 19 Sep 2012, 18:45
OK
Installing the USB - SERIAL is causing you trouble?
Postby woodygb » 19 Sep 2012, 18:53
IF your running Windows 7 it should be a case of simply plugging the adaptor in...Windows will then connect to the net and find the FTDI Drivers needed.
Users browsing this forum: emilevirus and 298 guests
