Chair was able to tow well with me in it on flat ground, at the very least it will be usefull for putting the boat away if i do end up using the car to tow it.
void steering() {
// calculate relative direction to destination
int steer = gps.gprmc_course_to(storedLat, storedLong) - (currentCourse) ;
// check if negative number, turn into positive.
if (steer < 0) {
steer += 360;
if (steer > 180) {
steer -= 360;
Serial.print("CTD used for relay control - ");
Serial.print(steer);
Serial.println();
//Turn left
if (steer <= -20 && steer >= -180)
digitalWrite(left, LOW);
digitalWrite(right, HIGH);
else if (steer >= 20 && steer <= 180)
digitalWrite(left, HIGH);
digitalWrite(right, LOW);
else
LROBBINS wrote:Have you tuned the motor compensation? If too low, it will have trouble with "high load" situations, including turn-in-place. Careful though, too high and the chair can become unmanageable, even to the point of runaway behavior.
Burgerman wrote:It makes it easier to drive. The load compensation when set correctly, automatically compensates for load. So the chair will respond the same, either loaded or not, slope or not, grass or tarmac, hill or no hill.
When its not set high enough you must add more power to overcome a load or weight yourself, and then it runs away after you do it. Or it refuses to turn. When set even fractionally too high it over compensates and can run away.
... This may seem like a daft question but ...because when i get off the chair lifts off the ground
woodygb wrote:... This may seem like a daft question but ...because when i get off the chair lifts off the ground
Why does the chair lift up? .... I always thought that you set the nose weight of the trailer hitch at 10-15 percent of the trailer weight... thus it should be pressing down on the ball hitch attached to the rear of the chair.
OR ...Do you mean that the casters are lifted off the ground without your weight on the chair?
woodygb wrote:A question about the deadband.
Why so big.... and doesn't the controller also take care of deadband?
woodygb wrote:Tony is this interface instead of a joystick/pod ...or will it work in conjunction with an existing pod ?.
Users browsing this forum: shirley_hkg and 49 guests
