Burgerman wrote:Or ring terminals.
Mind The Gap wrote:Hi all, Home from hospital at last. Have charged batteries and put away in box for few weeks.
Been re-reading battery threads and noticed something in the Expresso addon thread about being one big battery, does this apply if mixing 8s7p 15amp main pack with 4s8p 12amp addon on pack. What I'm asking is it ok to mix 15 amp and 12amp together.
Cheers Paul
Mind The Gap wrote: What I'm asking is it ok to mix 15 amp and 12amp together.
Cheers Paul
expresso wrote:Now if you are going to have Lithium pack inside the Chair and also an ADD ON outside the chair - connected together - When in use its working as One big pack - BUT to charge that - you have to disconnect the ADD ON pack from the Main Chair pack and charge each one on its own separate -
i do my other chair that way since i have the same thing - 105ah inside the chair and the ADD ON 30ah outside - when i get home - i disconnect the Cable that is connected to the ADD ON going to the Chair Pack - then its two packs - disconnected from each other -
i have a few PL8s - i use one to charge the ADD ON on its own - and connect the other one to charge the Chair Main pack on its own also - - When the Charge is done on both packs - i then reconnect the Cable that connects both packs together as ONE Pack - and ready to use again -
you can't charge both packs when connected together - they need to be charged disconnected from eachother -
Mind The Gap wrote:, does this apply if mixing 8s7p 15amp main pack with 4s8p 12amp addon on pack. What I'm asking is it ok to mix 15 amp and 12amp together.
Cheers Paul
shirley_hkg wrote: My mechanics is always ready .
It's simple , if I have a hub to follow through ..
Happen to find a 636 nearby . Does it use the same hub ? I can borrow it for a while .
shirley_hkg wrote:Mind The Gap wrote:, does this apply if mixing 8s7p 15amp main pack with 4s8p 12amp addon on pack. What I'm asking is it ok to mix 15 amp and 12amp together.viewtopic.php?f=2&t=6873&start=440
Cheers Paul
Oh. Sorry . Slip through my eyes .![]()
8S7P pack cannot work with a 4S8P pack , no matter what capacity they have .![]()
?flex
ex-Gooserider wrote:More of a concern is that if you heat the wire enough, the molten solder will wick up the wire away from the joint, making the wire into a solid, which is then a stress point that is likely to fail at some later point.
Burgerman wrote:Your lithium pack connects to the 0V and the 24V terminals.
Burgerman wrote:Your "technician" is an idiot.
Honestly thats like asking a vet which is the front and rear of your dog.
Find a competant person before yours hurts himself or you. If he cant tell just by a quick glance at the cables, and he can, then just test with a volt meter. The two that show 24 or 25 volts are it...
Users browsing this forum: No registered users and 344 guests
