Colour codes vary and can be almost any combo ....I would however suggest that it's probably WHITE = TX and RED = RX ... I often "pop" open the USB cases on new makes/models/suppliers and look.but it only had 3 wires( red/white/blk )
woodygb wrote:Have you turned the pod on?
I also find that is necessary to restart the PGDT software each time I make a change to my leads ..swap them or change ports etc...
Burgerman wrote:You need to restart everything, PC, chair, software, etc. And try every port. Mine like com8 and ignores all the rest. My laptop only works on com1
woodygb wrote:The pod lights should just show the battery charge state ...no "ripple"...which suggests to me a possible cable error.
Burgerman wrote:Bad conection at the charge port?
woodygb wrote:Doug...
None of my leads give a charging flashing sequence if plugged into the charging port ...either with the USB of the programming cable connected or with the USB disconnected.
I think that you may have an inhibit / ground problem of some description with your cable.
Woody
woodygb wrote:4.7k? ... I use 47k.
Users browsing this forum: No registered users and 472 guests
