woodygb wrote:Mike,
Your lead uses a different chip set ... which suggests that it is indeed an XP Pro problem ... is your DELL running XP Pro?
Or perhaps a USB problem ...e.g USB 1.0 on the earlier computers and USB 2.0 on the later models.
http://www.diffen.com/difference/USB_1.0_vs_USB_2.0
rustyjames wrote:Did you use the diode when you made the up the cable? I have a cable I made up without the diode and it does the same thing. What operating system are you using? The cable that I made up will work fine with Win. 7 Home 64 bit, and XP Home 32 bit, but will do what yours is doing with XP Pro.
IS it this controller?Return to Everything Powerchair
Users browsing this forum: LROBBINS and 418 guests
