Very very sorry...
It has it uses though BM!
Very very sorry...
Burgerman wrote:To give you some idea of whats possible I just offered and was accepted £4400 for this chair linked below, with a centre power footrest fitted in place of the swing away ones. Its UNUSED and is the highest spec possible. Every expensive option was ticked. Even a faster 10A charger.
It was ordered new, sold in Aug, and returned the same month unused for whatever reason. Maybe too unwell or worse...
A £12K chair (I added up all the stuff on the prescription form), for all intents its literally brand new, for 1/3rd the price. With a 12 month warranty and power centre footrest included.
I used 2/3rds my Power Wheelchair Budget to pay for it 1 hour ago...
https://www.ebay.co.uk/itm/SUNRISE-QUIC ... Sw0GlfiE7A
SAME seller has many cheaper chairs for sale too.
https://www.ebay.co.uk/str/SOLUTIONS-MO ... 7675.l2563
ex-Gooserider wrote:First off, welcome to the forums, you've been getting a lot of good advice...
A few things..
1. Invacare sells the same 'H-frame' RWD chairs under several names - Arrow, Storm, Torque, Ranger-X and possibly others... The frames on all are the same, the differences are mostly the accessories in stock trim, and things like motor choices, etc.
2. Airlines should NOT be taking your batteries out, or otherwise taking your chair apart - the rules require that you must be able to disconnect the power or take other actions so that the chair can't be turned on accidentally.... However as long as you are using 'Sealed' (i.e. gel or AGM) batteries they should NOT be removing them. It is also a good idea to remove the joystick pod (which by itself makes it impossible to turn the chair on) and any other fragile / easily removed parts and pack them in a carry-on suitcase in order to protect them from the baggage handling gorillas...
3. Your provider really can't stop you from adding any kind of 'bolt-on' modifications - as long as you can return the chair to 'as delivered' configuration whenever they want it back, they have no grounds for complaint (however the mods can't break their stuff, and you can't expect them to fix them....) Of course one of the advantages of getting a used chair is that YOU own it and can do whatever you like to it.
4. Even with the best chair suspensions, solid tires will give you a rough ride. A tubeless tire w/ sealant is just as reliable and will soak up a lot of smaller bumps and irregular surfaces that will go right through any other suspension. You will also find your choices in solids are very limited.
5. Do you / your parents have access to any kind of machine shop / welding services? This can be a big help in getting things you want made...
6. You need to be a very strong self advocate - don't let a supplier tell you what they are going to give you, instead INSIST on getting what you need... It sounds like you are dealing with a government agency for your chairs, if so, don't be afraid to contact your elected officials (Senators & Representatives in the US, I believe you have 'Members of Parliment'?) as they can often apply heat from above to get things unstuck... They approve budgets, so agencies dependent on them tend to be responsive.... They want to keep getting re-elected, so they like doing things for constituents in hopes of getting your support... Burgerman is from the UK, so probably a different system, but the general techniques he uses to work the system still apply...
steves1977uk wrote:You will need the motor and battery connector kits from CW if you plan on keeping the original motors and wiring looms. Also order a couple of spare R-net bus cables since they're cheaper if you buy direct from them.
Moosh89 wrote:steves1977uk wrote:You will need the motor and battery connector kits from CW if you plan on keeping the original motors and wiring looms. Also order a couple of spare R-net bus cables since they're cheaper if you buy direct from them.
Got a link?
steves1977uk wrote:Here's the part numbers you'd need... viewtopic.php?p=78258#p78258
Hope this helps Moosh!
Burgerman wrote:Personal opinion. You are way better off finding a chair that already has R-Net if thats what you want.
Because otherwise things get complicated if you dont know what you are doing. Yes that means nothing from invacare.
And buying this as a one off from PG Drives (Curtiss) may or not be difficult as an individual. Or in some cases impossible. They will not want to sell you a OEM programmer just to begin with. There are ways though. Later...
The price may be rather high even if they allow it. New prices can be severe! Again it depends who you are, and if they will sell to you and even what country you are in.
You might also read this carefully.
viewtopic.php?f=2&t=8857
Theres ways to do this very cheaply. Or ways to do it that result in telephone numbers. And PM me for a link to a OEM programmer...
I also think you need a main daily chair. And if you want to mess about, prototyping etc you then build a 2nd chair.
We will have a wheelchair specialist shop like Golden Mobility do it (convert to R-Net). And take it to SaskAbilities to get my seating fitted.
martin007 wrote:What is all that you have added?
martin007 wrote:I understand.
Can I ask you a question?
Do you live in a house?
I see you have a lot of room.
Burgerman wrote:Lots of room! And less than 1 million people. Its the opposite to most places. Very wild, beautiful and unspoiled.
https://www.google.com/search?q=Saskatc ... 0&dpr=1.25
But not really very chair freindly.
Users browsing this forum: Google [Bot], Jay_x, jefferso, wes4dbt, woodygb and 45 guests
