I am about to replace the DX2 system on my Magic Mobility X8 with a used R-NET system. I have a few questions if any body can help me.
1. The R-NET controller I have has a small device plugged into the far right port that has a label on it that says” REMOVE FOR TILT OR LIFT”. Is this device needed in every R-NET system if you are not using that port. Although my X8 does not have tilt or lift I have another R-NET controller that I am going to install on another chair I have and I do not have this small plugin device for that controller.
2. Is there a polarity to the motor plugs terminals? I am sure if I hook it up and it goes in reverse I will know I have it wrong but I would like to get it right on the first try.
3. Which side of the chair would motor 1 connect to?
4. I assume there is no polarity to the brake circuit and I can just connect the two brake wires to either terminal. Is this correct?
5. The OEM software I got with the dongle says version 6.1.0. Is there a newer or better version of the software I should be using?
6. Since I have a used R-NET controller that is set up for who knows what and I have no idea what the old DX2 controller had for settings is there anything I need to look for or does anybody have any recommendation on where to start with settings?
I know that is a lot of questions. I am always grateful for the help I get here. Thanks everyone and special thanks to Burgerman for this great site.
