is there a better version?
Postby duke1 » 23 Nov 2020, 15:44
hi all both my tinas outdoor chairs use these for securing the motors and i have had to replace them several times and am looking for a stronger heavy duty type that can take a little abuse and not be all floppy in a couple of months,now as far as i can see they appear mostly to be identical bar some have a seal.
theres no scope on either chair to enlarge the fitment so must be m8 is there anything you guys know of that lasts longer? cheers
https://www.ebay.co.uk/itm/M8-Ball-Sock ... 4259889526
duke1
Re: is there a better version?
Postby Burgerman » 23 Nov 2020, 16:03
never saw a motor that didnt bolt on. what/how does that do?
Postby duke1 » 23 Nov 2020, 16:50
Burgerman wrote:never saw a motor that didnt bolt on. what/how does that do?
axial motors are mounted to the swing arm and stabilised by 2 threaded bars as in pic
duke1
Postby woodygb » 23 Nov 2020, 18:23
You MIGHT be better off using rose joints.
https://www.ebay.co.uk/sch/i.html?_from ... od+ends+8m
You might also require
https://www.ebay.co.uk/itm/M8-Rose-Join ... Sw1KxXM2p8
And of course some suitable M8 bolts.
Postby Burgerman » 23 Nov 2020, 18:33
Rose joints come in super high quality, and not... No doubt the £££ ones will be better.
Postby Snowy » 24 Nov 2020, 05:10
Can you give the make and model of this chair?
Snowy
Postby shirley_hkg » 24 Nov 2020, 07:37
Might be adjusted too short the stud.
Should allow some play for swing arm .
Postby duke1 » 24 Nov 2020, 20:58
Snowy wrote:Can you give the make and model of this chair?
viewtopic.php?f=2&t=4666 :thumbup:
duke1
Users browsing this forum: shirley_hkg and 21 guests
