I agree. But hes bought this now.
Tail current - Some lithium battery chargers stop charging when the current drops below a set threshold. The tail current must be set higher in this case.
So if you set say 250mA as the termination current on a PL8 then this should be set to say 500mA or even 1A or 1% of a 100Ah battery or .5% of a 200Ah battery? So that it can tell the difference between it ending the CC stage and the balance, and CV stage and determine if its really full or not? So what you set this to depends of what you set the termination current to in the PL8 settings. And must be greater. But not too much greater. Maybe double?
Discharge floor This setting is used in “the time to go” calculation and is set at 50% by default. But lithium batteries usually can be discharge significantly deeper than 50%. The discharge floor can be set to a value between 10 and 20%,unless the battery supplier advises otherwise.Important warning. Lithium batteries are expensive and can be irreparably damaged due to very deep discharge or overcharge. Damage due to deep discharge can occur if small loads slowly discharge the battery when the system is not in use. Some examples of these loads are alarm systems, standby currents of DC loads and back current drain of battery chargers or charge regulators. A residual discharge current is especially dangerous if the system has been discharged all the way until a low cell voltage shutdown has occurred. At this moment the state of charge can be as low as 1%.
But it doesent know the cell levels. So this setting is pretty much a guess. I would set to 10% and that leaves a 10% margin for individual cells discharging below that figure. Without wasting 36Ah of his battery!
The lithium battery will get damaged if any remaining current is drawn from the battery. This damage can be irreversible.A residual current of 1mA for example can damage a 100Ah battery if the battery has been left in discharged state during more than 40 days (1mA x 24h x 40 days = 0.96Ah).The SmartShunt draws <1mA from a 12V battery. The positive supply must therefore be interrupted if a system with Li-ion batteries is left unattended during a period long enough for the current draw by the SmartShunt to completely discharge the battery.
So fit a BATTERY switch as the chairs system also takes out power. An anderson loop, or a accessible battery plug etc or whatever is easiest.
As for the correct voltage at setting 2, then you want to choos a figure that shows its fully charged. So a safe figure is 3.5V per cell, or 28.4V.
Why? Because the current 29.2V setting is or should be way above the charge voltage of 3.6v x 8 = 28.8V And we charge at 28.8V and so this must be set at a little less like 28.4 to 28.6V to be sure we exceed this. In use a FULLY charged battery can be between 28.80V straight after charge, and within a hundred yards that will fall to 3.4V or below. Typically 3.38Volts or similar. The rate of voltage drop is far flom linear!
You might want to buy a cell log and check when the chair is near empty, to be sure you are not damaging a weaker cell already. With 10% in reserve that should not be an issue. But best to know.
