That's certainly what I'd do, and it's also what you do with the PL8. Given that it also has a remote on/off connector to which the charger could be connected, it can be completely inactive except when the charger is live.That could be used only to charge if the motor controller was directly connected to the battery rather than the BMS.
expresso wrote:this may sounds crazy - i dont know - But - What if we can just use a BMS modular - not connected to the battery at all during use
and just plug it in when charging ? we make all the connections we need and mount them to the chair - do the same on the BMS side
like we do our own charge cables etc, - dosnt solve what the BMS does - but at least during riding - no BMS and no worries of cutting off or how many amps it does etc,
it will only be connected when charging to balance - 100A would be enough for that -
doesn't any one - China - make custom made BMS ? cant we write up what kind of BMS we need and have them make one that way ?
Burgerman wrote:You connect the wheelchair directly to the battery and dont charge via the XLR.
You connect the BMS to the battery cell wires, and the battery main wires, and charge via the BMS charge wires. Needs a seperate charge connector connected to the BMS.
Thats all.
I know what options are on the modified presets. I know it isnt.
I will give you a single example from many. On the PL8 I can change the point where it monitors the charge where it allows a max cell gap of 250mV to 350. Because otherwise when we have an unbalanced pack that exceeds 250mV the charger goes into a thing called safety charge and starts charging at a very low current... 0.5A. Indefinitely. On a LiFe pack that happens all the time if its a bit out of balance. On a small hobby pack thats not an issue. But you cant charge a 200Ah pack at .5A as it will take 400 hours! And its limited to 16 max. It isnt needed on LiFePO4 anyway and is a left over from the lipo algo they use for "safety"... I can also move te trigger point above the charge voltage we use, so that it never kicks in to stop us charging even highly unbalanced packs. Which I also do.
Theres many more small changes that I make. No PC software means I cannot do this... Or any other behind the scenes stuff. It affect lead and lifepo4. And more. So its a definite no here! Not interested.
Other chargers have similar hidden things that screw us up. Or may do. Extensive testing finds these. But then starts the arguments with the manufacturers like I did with hyperion and revolectrics in the end to fix things. So nope! No use to me. If you dont mind struggles with problems where it wort charge because of all the safety nazi stuff then go ahead! Its also why you must use my presets even if you change everything. Theres hidden stuff!
Users browsing this forum: FishMan, MarkFox, shirley_hkg and 66 guests
