Leveling a C300
Leveling a C300
Postby Rye » 27 Jan 2021, 23:55
I'm trying to fit a pair of 2.80/2.50-4 Primo castor tires on my C300 to compensate for the taller drive wheel tires. I'm using the castor forks/tires from my P222. There is slight rubbing on the rear plastic though. Has anyone fit taller tires on a c300? If so, what size? I've adjusted the shocks out fully with the stock castor setup, but it still dips back. The larger P222 tires would make it sit pretty much level I think. Front tires are worn, but size 3.50-8.
Rye
Re: Leveling a C300
Postby Burgerman » 28 Jan 2021, 00:18
I might be looking for some longer shocks?
Re: Leveling a C300
Postby Marcelo » 28 Jan 2021, 16:51
Rye wrote:I'm trying to fit a pair of 2.80/2.50-4 Primo castor tires on my C300 to compensate for the taller drive wheel tires. I'm using the castor forks/tires from my P222. There is slight rubbing on the rear plastic though. Has anyone fit taller tires on a c300? If so, what size? I've adjusted the shocks out fully with the stock castor setup, but it still dips back. The larger P222 tires would make it sit pretty much level I think. Front tires are worn, but size 3.50-8.
Tire a porca que trava a mola, e estique a mesma. só dá trabalo recolocar a porca ok.
Pode tanbém colocar um amortecedor maior.
Podem me sacanear por essa ideia ok. czy
Marcelo
Re: Leveling a C300
Postby foghornleghorn » 28 Jan 2021, 19:04
Does it make a difference if you mount the shock in the front hole?
Re: Leveling a C300
Postby Rye » 28 Jan 2021, 21:11
The lower hole drops it slightly. I'm trying to find some different shocks, but finding a good match might take a bit. I used to drop the air pressure on the drive wheels, but that would wear them out quickly. However, when fully inflated the castor tires would wear out quickly. I could just ditch the rear plastic and relocate the PM. then there'd be ample room for the larger tires. It might not look so clean though. It's just a farm chair so I'm no obsessed with style.
Rye
Users browsing this forum: duke1, FishMan, MarkFox, rover220, shirley_hkg, woodygb and 61 guests
