by Burgerman » 09 Feb 2021, 00:06
If we really want to get the best cycle life from a lead battery of all types we would charge them at their best float value. So say 13.45 on a gel battery. 13.6V on an AGM battery. But that would take around 3 to 4 days to fully saturate the cells. To reach a completely 100% charged state. This is because these voltages are low enough that there is no grid corrosion caused or gassing involved at all. So these will prolong battery life and cycle life. But we dont have days to charge.
Its important to get to 100% charged because otherwise some lead sulfate remains on the surface of the plates. And inside of the lead "paste" that is made of finely ground lead particles that is pasted inside of the plate. If we remove a battery from charge before its 101% fully saturated with charge then some of this sulfate remains instead of being returned back to the acid/electrolyte. And it builds up every single charge. The problem is that in time, esp when warm, it turns into larger crystals that no longer conduct electricity. At this point they are there forever which reduces capacity and increases internal resistance. Both of which make charging harder, and slower, and reduces range.
So in order to get a good (but not complete) charge overnight as thats all the time we have. We must force the energy back in faster. The way we do that is to use more volts. And it doesent take much! So with 20C room you would use 14.7V (29.4) with a quality ODYSSEY type battery. And 14.4 to 14.7V depending on the manufacturer spec for normal AGM. And 14.1V (28.2) for GEL batteries. We cannot keep doing this for many many hours however like we can at float voltages, as it will cause excessive gassing and grid corrosion issues. So we generally do this for a max of 4 hours if a battery is almost full. Up to 12 hours for a battery that has been deeply discharged. MAXIMUM. 8 hours is usually the best CV voltage maximum general setting.
Or until the charge current has stopped falling over say 1 hour period. Or end charge at 1000th of capacity - so 74mA plus 20mA for the drain current of the OFF wheelchair on the MK 74Ah battery. Whichever occurs first. Or we stop charge when charge current is still around .5A and then go to a lower float voltage. This usually results in a battery that is as full as we can get in the 8 to 10 hours overnight. Probably 99%. But that leaves that 1% to 2% which means that theres still some deep lead sulfate inside the lead paste in the grids. We can use the chair. Get 99% range. Its the best we can do in the time we have available. But we should leave the chair on a float charge for a couple of days at least 2 or 3 times per month if possible. Every day you get a chance! To return that lead sulfate back to the acid from where it came. Theres no quick way.
Correct charging, and correct accurate charge voltages, along with leaving the battery on charge after the green light on float as often as you can is the difference between all those complaining that these batteries are not what they used to be, or replaving them frequently or other battery issues. And long life reliable performance. So like the vast majority, you dont have to bother! Anything will charge them! In a fashion. But those that understand dont keep throwing them away! A little knowledge is as always power.
