Problem with Dynamic joystick rem 24 SD
Postby salam321 » 09 Feb 2021, 20:53
Hello, can anybody help me in showing me how to open this joystick to repair it, i tried everything almost
salam321
Re: Problem with Dynamic joystick rem 24 SD
Postby martin007 » 09 Feb 2021, 21:14
Hello salam321
Can you upload a picture?
Postby Burgerman » 09 Feb 2021, 21:23
Theres a screw under the nameplate. Ustick it.
Postby salam321 » 09 Feb 2021, 21:29
There is only 3 screws and i opened them alredy, but still not enough, i though maybe there is somme special technic to open it
Picture coming..!!
salam321
Postby salam321 » 10 Feb 2021, 19:53
Yesssss you were right, 2 screws hidden under the name, thanks man.
salam321
Postby salam321 » 11 Feb 2021, 01:33
Now that i opened it i don't know from where to start, the code signal i get when i try to start the chair is number 1 (first led)
salam321
Postby martin007 » 11 Feb 2021, 01:35
Postby Burgerman » 11 Feb 2021, 01:37
Flat battery? Or if part of a flash code then a defective module. Why have you took it apart?
Postby woodygb » 11 Feb 2021, 02:06
Postby Burgerman » 11 Feb 2021, 07:54
Unplug all the bus cable, reconnect after a little spray switch cleaner. If problem still exists in may be the power module or the seating module.
Postby salam321 » 12 Feb 2021, 17:30
Problem solved, don't know exactly how, but i have doubts about a little wire coming out from inside that might've touched a screw next to it
salam321
Postby Burgerman » 12 Feb 2021, 20:14
Did you repair it? Or are yo guessing? Because the error code did not point to a joystic error.
Postby salam321 » 12 Feb 2021, 22:29
honestly i just opened it, checked it, then closed it again, no reparation at all, before opening it i tried it on another wheelchair and it gave me the same error signal, that's what let me conclude that there is a problem with the joystick not something else.
salam321
Postby salam321 » 11 Mar 2021, 22:48
Nope, still the same problem, it worked only for a while, i had doubts about the joystick cable, since it's damaged arround the 4 pins, but when i used another dynamic joystick rem 24 sd, it worked fine, i don't know what to repair exactly, inside it looks completely fine
salam321
Postby Burgerman » 11 Mar 2021, 23:16
Well at least start with the cable!
Postby salam321 » 12 Mar 2021, 21:56
Bye bye Joystick, i can't use it again even if it works, the trust is gone..
salam321
Postby Burgerman » 12 Mar 2021, 21:59
You are not being logical. Who says anything at all was ever wrong with the joystick? SWAP the CABLE!!!
Users browsing this forum: Google [Bot], rover220, Williamclark77, woodygb and 53 guests
