Anderson connectors
Anderson connectors
Postby Burgerman » 14 Feb 2021, 03:11
For those that dont quite grasp how useful they are...
I fit them to everything. The reason being it gives enormous flexibility. For e.g. theres one inside my van hidden inside the centre console. It allows my to start the van from my chair. And once started it allows the van to charge me chair very fast as I drive home. It also means I can conect a lithium charger and charge my van from the chair, or the chair from the van at high power. It also means I can charge my hobby stuff, planes, helis, etc from chair or van. And it means that if the van lights were left on while you were at a cinema or something, you can just plug in the chair. And start it. Theres another anderson under the front wheelarch... Why? Because I might want to charge my hobby stuff, and plug in the charger. Or use it to leave a maintainance charger connected over winter. And I do. It also means that if theres a power cut, my van is a generator. How? A 12v to 240V AC inverter. I have one in the luggage compartment just in case. That with an extention lead can run my house lights, freezer, electric bed, wheelchair chargers, etc.
Or allow me to use the AC vacuum cleaner outdoors in my van. Or run anything AC.
I Have Andersons on every wheelchair. Every power supply (4). My mower, my strimmer, my electric bed, several inverters, all my chargers and thats around 10 inc 2 hyperions, 4 PL8s, and various 12 and 24V marine, and 30A ones. And many other things besides. For e.g all my solar system, at each panel and as a higher voltage serial set, and battery backup. I have plenty of long cables too. Inc 12V and 24V series parallel adapter connectors and Y junctions.
Even a cordless drill. No more dead battery as you work. In fact no dead battery! It amazes me that theres so many things that can be connected, powered, charged, or run from vans, wheelchairs, etc.
Re: Anderson connectors
Postby rickystyx » 14 Feb 2021, 11:28
Having a stupid Skoda that once the battery dies on you you can only open the drivers door all the others being electrically locked and you can't open the bonnet without opening the passenger door so you have to start stripping the bonnet catch apart to operate the cable, just what you need when you are not physically able - having a set of Anderson connectors inside the car that I can connect the chair to also allows me to connect the Shirley charger to the battery in emergencies - it is an absolute savior
ottobock b400 150Ah lifepo4
rickystyx
Postby Burgerman » 14 Feb 2021, 11:32
You can start it directly from your chair or open it too. You just need one under the wheel arch as well. As long as your chair is wired with 2 12V parallel/series connectors.
http://www.wheelchairdriver.com/gopro/starter.mp4
Postby ex-Gooserider » 16 Feb 2021, 00:08
I have both the PP-75 Andersons (which I prefer to the SB-50's for chair connections) and a PP-15/30/45 connector on my chair, as I find the smaller power-poles less cumbersome than the SB-50 or PP-75 for lower power things. (IMHO the plug shouldn't be bigger than the thing it's powering....)
I have SB-50 plugs on both the inside and outside of my van...
I have also made a set of jumper cables that I keep in the back of the van.... It is fun when someone has a dead battery in their car and you help by giving them a jump with your wheelchair....
Users browsing this forum: Google [Bot], rickystyx, wes4dbt, woodygb and 36 guests
