PL8 error bad cell count ?
Postby expresso » 18 Feb 2021, 03:22
Ok i just finished my 200ah pack - everything looks good to me - everything is tight - i went to plug it in first time to charge and get bad cell count error
do you see anything wrong from this picture that i dont see ?
Quickie P222se - 60Ah ADD ON
Quickie P220 - Indoor Chair
Bounder Plus - 180Ah LifePo4
Re: PL8 error bad cell count ?
Postby expresso » 18 Feb 2021, 03:30
safely code 20 bad cell count - i just tried it with out the charge cable i made - so its not the cable thats bad - something is wrong on the Battery end -
not sure what it is :o
Postby expresso » 18 Feb 2021, 03:43
i checked each cell with volt meter - all show 3.3 - total pack 26.7v
i checked the balance wires and followed each wire to each cell - - all check out -
the first cell gets neg and #1 wire - the rest get 2 3 4 5 6 7 8 all on the Pos post of each cell -
why would i get a bad cell count ?
Postby shirley_hkg » 18 Feb 2021, 03:53
WRONG !
Postby expresso » 18 Feb 2021, 03:54
i just connected it direct - no balance wires - it works - so it has to be the balance cables - either connected wrong which i dont think
or when i made them - something didnt work on one or a few of them ? not hard to do - first time this happened - crimp and heat shrink
done them all the same way -
Postby expresso » 18 Feb 2021, 04:07
i see the problem - with the balance wiring - but cant figure out how to fix it - the balance wire Pos needs to be with the pos power cable - i notice that on my other packs - but it dosnt end up this way on this way
the layout of the cells how i build it - is throwing me off -
can any spot the issue and how to fix it - its a matter of wiring - needs to be rearranged - but cant see how
Postby expresso » 18 Feb 2021, 04:10
WRONG !
Ok so the neg balance cable needs to go on the Neg power cable ? and thats it ?
anything else you see thats not correct ?
Postby expresso » 18 Feb 2021, 04:22
Ok i just tried that - moved the neg balance cable to the Neg Number 8 cell and didnt work - still bad cell count
i cant figure it out - its something with the wiring - just dosnt end up the way it does on my other packs
something is still wrong - normally i notice on my other packs - the Neg. balance ends up with the Neg. power cable - and Pos balance ends up with the Pos power cable -
but the layout i used to build this one - is confusing me now - they dont end up correct - the balance cables -
Postby expresso » 18 Feb 2021, 04:30
this is the pack - the layout - with no wiring - can someone figure out how to connect them that ends up with the correct balance wires in the correct cell ?
but it correct without the balance wires - the pack is fine - the balance wiring is wrong - its confusing me now - any ideas - what else is wrong with the balance wiring ?
Postby shirley_hkg » 18 Feb 2021, 04:41
You shouldn't have 2 leads on 1 node.
Start with the first balance wire on the pack's neg.
Then all the other 8 leads to each of positive terminals
Postby expresso » 18 Feb 2021, 04:53
ok which way - which number Cell - i have them numbered -
which way should i start - i will remove all the balance wires and start over
neg balance wire on Neg Cell with the sticker 8 ? and should end up with the Pos balance wire on Pos Cell with sticker number 1 ?
one cell will get two wires - 9 balance wires and only 8 cells - one of the cells get two wires - i always done it that way before
but this layout is tripping me up
Postby expresso » 18 Feb 2021, 05:15
Ok its working now - i removed the balance wires and started from Cell number 8 - these are the numbers i put on the cell my own stickers
so it was backwards - Cell 8 is now Cell 1 - - i will change my stickers so i dont get confused again - - but its fine now
thanks - but the first cell gets two balance wires - neg. 0 wire and 1 - the rest get one wire on pos of each cell :joint
Postby expresso » 18 Feb 2021, 05:41
fixed - relabeled so not to confuse me - i was having a senior moment i guess - :lol:
Postby Burgerman » 18 Feb 2021, 11:35
You must be a little careful wiring u these cell balance wires. It IS possible to damage the PL8 if wired in the wrong order or worse make smoke too. So whilst this may not have happened to you, just a warning for the future and others that are following.
Postby shirley_hkg » 18 Feb 2021, 14:46
It's wise to follow the norm, as PL8 does, denote the Neg as cell 1 .
Postby expresso » 18 Feb 2021, 17:20
i have to remember for next time - - to always start with Neg. and label that Cell 1 - its all good - charging up now for the first time -
maybe i do a full discharge with the pl8 - and recharge - - then it sits till i get my chair - could be a month or two before i get it
How bad is it if i didnt use a cover on top of the pack ? if i just slide it in the chair with no cover on top - besides it gets dirty -
any reason that is a problem if i didnt cover it on top only ? i rather cover it - but space looks like its going to give me a problem -
Postby expresso » 18 Feb 2021, 17:23
thanks :thumbup:
Postby expresso » 18 Feb 2021, 17:24
Burgerman wrote:You must be a little careful wiring u these cell balance wires. It IS possible to damage the PL8 if wired in the wrong order or worse make smoke too. So whilst this may not have happened to you, just a warning for the future and others that are following.
at least we know the safely features of the PL8 work - it just gave me error and nothing worked - - thats a good thing
Postby ex-Gooserider » 23 Feb 2021, 04:14
expresso wrote:i have to remember for next time - - to always start with Neg. and label that Cell 1 - its all good - charging up now for the first time -
Electrically it shouldn't be a problem to not have a cover, at least assuming that your dirt is minimally conductive.... However what happens if you go over a big bump and the pack bounces up and hits the top of the battery area? Is that metal? Could it cause a short?
Basic idea is that best practice is to ensure that nothing can possibly make contact with the terminals, no matter what happens.... Insulation is your friend!
Postby expresso » 23 Feb 2021, 04:47
yeah i agree - if i didnt add anything on top - and it bounced that hard - its plastic on top anyway - but what i did is - i wrapped each post with some graphing tape - just not to leave them exposed - and i will add that plastic board i got - and layered the bottom of it with silicone -
so the silicone would sit on top of the posts covered in graphing tape - - tape it down with duct tape and cover the sides so nothing can get inside - i wrapped the whole pack - best one i did so far - my only last concern is - if it fits now - it will be a tight fit -
i may have to remove the top cover from the chair first - then slide it back over it - best i can - i will see - chair should arrive in two weeks
Users browsing this forum: Arima, DirtinLa, Google [Bot], Heygnow, wes4dbt, woodygb and 28 guests
