Just found an old vid from my GFs camera. A slowish 3 or 4 mph wheelie. Just trying to show here it cant turn over no matter how hard I hit the anti tip wheels on the deck on purpose.
image http://www.wheelchairdriver.com/images- ... r-1200.jpg old chair in video (but rebuilt +slightly modified etc)
image http://www.wheelchairdriver.com/images- ... rchair.jpg new chair...
http://www.wheelchairdriver.com/images- ... eelie.mpeg vid of old chair...
This was an old chair with "normal" wheels (although tubeless tyres, reprogrammed, seat relocated, etc). And "normal" anti tip wheel position but replaced by smaller skate wheels so they are high enough to wheelie. But still long enough to hit everything...
This tippyness (with a little more finness) and less forward speed than shown here, with just enough height to just lift the front wheels over the curb is how I approach up to 3 inch curbs too. Now 4 inch+ with the newer fatter rubber chair.
It means that just the two rear wheels have to climb it and you have momentum. With the latest chair and its fat soft all terrain tyres http://www.wheelchairdriver.com/ultimat ... rchair.htm these rear wheels easily go up with hardly any bump. They just absorb the curb... Its pretty smooth. I go off curbs the same way. Will get a vid one day soon.
But the anti tip wheels are now shorter, higher etc. (see pics) It CAN now be turned over if you are really enthusiastic, if you just shove the stick forwards like a loony and hold it there... Or go up too steep of a ramp forwards! Bit like a sports manual chair. Bit lively!
Obviously its (both chairs) also got a bigger and seriously re-programmed controller too. So its very controllable. Unlike all stock powerchairs.
