q700m wrote:can you find the user manual PROGRAMMATORE DTTR-NET/ VR2 ?
I can't find anything about this programmer
> http://sunrise.pgdrivestechnology.com/m ... 809-02.pdf
> https://medema.no/files/Programmer%20k% ... er_OEM.pdf
Burgerman wrote:But... Those do not adress the HAND HELD programmer.
martin007 wrote:Burgerman wrote:But... Those do not adress the HAND HELD programmer.
I don't understand...
Burgerman wrote:martin007 wrote:Burgerman wrote:But... Those do not adress the HAND HELD programmer.
There is a HAND HELD programmer that does not need a PC. It doubles as a dealer programmer (so pretty restricted) and can store a few settings files for various chairs. It basically does the same as a DEALER PC software and dongle. It also does VR2 should anyone on here be interested in that.
There is a PC DEALER version for a PC based system, with a DEALER dongle. It does the same as the HAND HELD one above, but allows a bigger screen with better layout and maybe a few more options, easier to setout and configure everything graphically. And easy to update! Just ask ME for the newest version.
There is a PC OEM version too that uses a OEM software, an OEM dongle and allows adjustment of all the complex stuff too, e.g motor compensation etc, unlike the ones above. And so is the best option.
q700m wrote:Doesn't the DTTR-NET/VR2 PROGRAMMER use the same dongle files modified with the pc program?
if i write and rewrite the complete file on the controller the memory can fail, i use DTTR-NET/VR2 PROGRAMMER to send the files i edit with the oem programme on the pc
q700m
Users browsing this forum: acid_coke, iainsherriff, shirley_hkg, woodygb and 22 guests
