Cost is cheaper.
amy is not using life - why who knows
Because it doesent understand batteries. And has been told that lithium ion is more energy dense. And way easier to get to work properly with a BMS. But they burn. Very exitedly. If anything goes wrong. It has happened with cameras, scooters, laptops, phones etc and theres been a lot of issues. Even boeing dreamliner... But in most cases there isnt a disabled person that is unable to get away. If a phone or laptop burns you throw it on the floor. It doesent burn you to death in a massive fireball because you cant get off. Having seen this chemistry do this with my own eyes in many hobby batteries over the last 15 years I have a very healthy fear of the things.
If there was no fire problem, I would build a pack with them myself. But theres a few more problems. They allow you to build a pack that is around twice as energy dense (well not quite but much better). So a smaller lighter pack could be 150Ah. Instead of say 90Ah. But only if you use all of the rated capacity. And if you do that, you get between 200 and 700 cycles. Depending on exact cells choosen. Not the several thousand we all now expect. And they age faster through calender years too.
If you limit the charge voltage to say 4.1V per cell, and limit the discharge to say 3V instead of 2.5V you then have a cell that will last almost as long as a LiFePO4. Provided you carefully control temperature and dont take out big currents too often. Or charge fast too often. But now you only have around 70% of the rated Ah. This is what tesla do. And you still have the risk. One disabled user burned to death because of a lithium ion pack used by Ami, and they will be out of business. And everyone else will then think lithium ion (inc the safe ones like we use) are dangerous... And they will not want to go there $$$.
