by Burgerman » 01 May 2023, 21:27
Their new batteres are a gel/AGM battery. The AGM part plays no part in the chemical/electrical part of the equasion its just an inert seperator. They are actually the very same battery as far as I can tell, as the ones sunrise supply. They are 80Ah, gel chemistry, pretty good quality. They are a rebranded version of the Sunrise supplied, permobil supplied, battery. Same exact electrical specs, same sizes, shape, lifting "rope", same terminals and just different labels.
You can buy these from permobil, or sunrise, or you can just order the HAZE 80Ah GEL on ebay as the 3 are all the same internally. But they are £220 each at the moment.
As for the special permobil charger, whell it too is a gel/AGM generic one rebranded standard 3 stage charger. But it is adjustable internally for AGM or GEL. Wether this is actually the CORRECT settings is unknown. But thats all I can tell you about permobils "own" special battery and charger... They make neither. But have tied these "special matched components" together in their customers mind. All clever marketing. You can buy the HAZE 80Ah GEL battery cheaper I would expect on eBay. And chargie it or a "permobil or sunrise version, as the GEL battery that is is.
I orderd the HAZE ones for my backup chair. Works pretty well. Has more capacity than the MK, and similar impedance, and around 20% less cycle life. In theory. But its bigger, so lowwr average DOD means it actually should last just as long or better.
