I'm gathering the items I need to make Anderson connected charging cables/wiring and have a few queries that I'm hoping someone can assist with...
I have MK M34SLDG batteries in my chair, the spec says they have type C terminals that are 1/4"-20. Am I correct in thinking I need M6 ring terimals?
Do people use authentic Anderson connectors or Anderson-type connectors?
What wire diameter is best? My current crimp/wire stripper tool only goes up to 10AWG, I'm thinking that might not be big enough?
Finally, I'm looking at buying the IP22 victron smart 24V charger that does 8/12/16 A charging, if I put a fuse on the cables from the charger do I need on on my chair too? I'm thinking not, but want to be safe. What size fuse would be best, is 20A sufficient?
Thank you in advance, I'm super grateful to all you knowledgeable people.
