Burgerman wrote:Well maybe. I didnt look it up I just looked at some cables in my charge box. I did use .7 mm2 on my long extension charge cable though. Those are silicone so externally thicker insulation. As well as on the chair side. Fit the pins fine. But I am using the large SubD connectors.
2 smaller black and red bags are the .7 sqmm (silicone) and the Revolectrix balance wire at the top and middle are marked as 22swg which is a fraction smaller conductor.
The charge cables are marked 12swg - same as stock revolectrix and silicone. They get just SLIGHTLY warm to the touch at 40A. Not sure what the mm2 is.
On balancing its not really about the current carry capability but the fact that when a 3A "brake" is applied or less than this when almost balanced, the resistance makes the voltage seem correct when its not yet. We are talking about a couple of mV difference here as thats the balance target accuracy. So long thin balance wires mean that it keeps applying a load to a high cell then releases it before it should. Then it tries again. So balance ends up taking much longer. Ideally balance wires should be as low resistance as possible. Below 300mm is recommended by most charger makers. Of course if the cables have bigger cross section longer is also fine. If you only uses the stock 22swg and made them 10 feet long final balance would take a long time.
yes but what I am asking is this;Burgerman wrote:I bought a dozen 36 inch ones. You use 2 on a powerchair. But I use these things to charge lots of hobby stuff. And so far I got through half of them.
your 36 inch cable, is 36 inches long, 3 feet. The 36 inch cable connects to a D-sub, and from the D sub to the terminals has to be at least another two or 3 feet, let's say 3 feet. This means in total the balance cables that are balancing the pack in your wheelchair are 36+36 inches long, which is a total of 6 feet, yes?
swalker wrote:I used tinned copper wires to reduce the likelihood of galvanic corrosion. You can learn more about galvanic corrosion at https://en.wikipedia.org/wiki/Galvanic_corrosion.
For balancing wires, I used wires obtained from Revolectrix. Those are 22 AWG tinned copper with the proper connectors. Though Revolectrix is no longer in business, you can find similar wires in many places, including Amazon.
I used 10 AWG wire for the power leads and I used 6 AWG to connect the individual cells together.
You can see my complete list of items in the attached spreadsheet:
Users browsing this forum: rover220 and 23 guests
