LROBBINS wrote:The brakes themselves fail less often than the wiring and (on chairs that have them - which is most chairs) the microswitch that cuts power to the brake if in freewheel. So, the first things to check are the wiring - connectors clean and bright and tight fitting - and the freewheel mechanism - is it fully disengaged and is it adjusted so that the microswitch is "closed". You might also check the resistance of the brake coil - it should neither be a dead short nor open, but somewhere in the range of 10 to 100 ohms.
LROBBINS wrote:Do work the freewheel lever back and forth a couple times and then make sure it is solidly NOT in freewheel. It could be as simple as that.
Burgerman wrote:Ignoring the fault/frustration what is it like as a chair?
I need the rep to come back and program the joystick some more and he isn't being very responsive.
Jay_x wrote:on my brand new Invacare Aviva I keep getting this error code. The joystick randomly starts flashing red (instead of the usual green color) and the chair freezes. I shut it off, start it up again and everything is fine. It does this about once every two hours. It flashes six times, which the manual says means "Right magnetic brake fault"
What should I do about this?
chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/http://www.invacare.com/doc_files/60101835.pdf
fishinjunky wrote:Jay_x wrote:on my brand new Invacare Aviva I keep getting this error code. The joystick randomly starts flashing red (instead of the usual green color) and the chair freezes. I shut it off, start it up again and everything is fine. It does this about once every two hours. It flashes six times, which the manual says means "Right magnetic brake fault"
i also have Linx electronics.
when you get the error code are you driving over rough or bumpy terrain or hitting a big bump?
So he asked another tech and they told him to loosen up the zip ties that hold the cabling together as super tight zip ties could cause this. That sounds silly to me, but what do I know?
Burgerman wrote:This was in august. I suspect he wont be back till something goes wrong again.
Users browsing this forum: Bing [Bot] and 74 guests
