carlo67 wrote:I have only 1 profile now. I am wondering how to turn on the other profiles?
the other profiles options doesn't show up [see attachments]
Burgerman wrote:With a programmer. Very easy. But I wonder why you would want more than one profile.
If it is corectly programmed so it drives and steers properly, from super slow on speed 1 to full outdoor capability on speed 5 then that covers everything without a need for swapping profiles.
What would more profiles than achieve?
I have 2 profiles.
1. ALL SPEEDS.
2 EMPTY CHAIR.
Profile 1 is for indoor and out.
Profile 2 has only slow speed, and lower motor compensation so carers can move chair under easy smooth control when chair is unloaded.
Turn on/off like below:
Burgerman wrote:You already have profiles turned on.
See that line where it says input device? Thats the bit that determines which DEVICE (joystick, or omni, etc) controls the chair. JSM = JoyStickModule. Omni is Omni obviously. That is only set to 7 at the moment. Set to Omni or Universal (allow grab) and you will then have access to that profile on the Omni.
But again, why? It will not achieve anything other than having to change profile in order to change speeds. If you set those up properly in one single profile its much faster and easier to adjust.
Set like this:
And the OMNI will control profile 1,
the JoyStickModule controls profile 2,
and ALL input devices can control profile 3 for e.g. YOU set it to do as you wish. (but you only actually need 1 profile anyway!)
Heres how you set this:
If I were you I would set up 1 CORRECT profile for all speeds on joystick, one CORRECT all speed setup for Omni.
OR
I would set up just one profile, set it up properly so it does every speed exactly as you want and set it to universal. So omni or joystick use the same one. But that really depends on you, and your actual method of control/headset etc.
Burgerman wrote:Add 12345678 to the list of options available in each profile.
Why are you showing me that screenshot/photo?
The profile appears in the main screes as you change it.
To change profile just press lower left button. No menu needed.
Burgerman wrote:But thats not how it works. I dont have an Omni here but that is an omni internal setup programming thing I presume.
Burgerman wrote:Bring it here and I will figure it out!
Did you add the 12345678 items yet? Those are the things that are available in each profile.
Your user menu can have up to 16 items in its list. You need the Omni2 manual to find out how you set that up. Its not in the R-Net programmer. Its in internal programming menu I think. You do already have this profile thing enabled.
Tell me, can you send me YOUR profile to look at anyway?
Attach here.
9.2 Accessing Wheelchair Functions
The Omni can be programmed to access all the available wheelchair
functions in two ways – by Menu or by Sequence. The programmable
parameter that sets the access method is User Control.
carlo67 wrote:yes
now it is working on button on display unit
but it is not helpfulBurgerman wrote:Bring it here and I will figure it out!
Attach here.
Burgerman wrote:That shows me that your OMNI profile will never let you steer or hit a doorway properly at any speed and thais is why you WANT extra profiles.
Burgerman wrote:Why do you need different settings in different profiles?
This is entirely your choice. YES MY CHOICE
1. I am just interested in why?
With the settings you have now in the one profile you are using, you will never be able to hit a doorway or steer well and so will need different profiles for different speeds. But by having many different profiles to chhose from you will be able to choose between say 5 or 6 still terrible ones that all go at different speeds...
2. What INPUT device do you use (head array, proportional??? Latched? Joystick?) JOYSTICK [SEE ATTACHMENT]
3. How do you operate your menu? WITH BIG RED BUTTON
4. When your chair is turning, and you tell it to STOP turning, do you want it to still keep on turning left or right for 3 seconds?
NOBurgerman wrote:Why do you need different settings in different profiles?
With the settings you have now in the one profile you are using, you will never be able to hit a doorway or steer well and so will need different profiles for different speeds. But by having many different profiles to chhose from you will be able to choose between say 5 or 6 still terrible ones that all go at different speeds... IT IS WORKING FOR ME VERY WELL
Burgerman wrote:Then go to your internal omni programming and to this:
USER CONTROL and add the required menu item, PROFILE.
You can add up to 16 items in any order.9.2 Accessing Wheelchair Functions
http://countries.permobil.com/Documenta ... l%20IR.pdf
page 36
NO
Burgerman wrote:4. When your chair is turning, and you tell it to STOP turning, do you want it to still keep on turning left or right for 3 seconds?NO
Well then, in your programming why do you have TURN DECELERATION set to 30?
And then you have MINIMUM TURN DECELERATION set to 20?
JUST these two settings alone will make your chair KEEP TURNING for around 3 seconds AFTER you choose to stop turning. Even if you apply OPPOSITE turn...
This (and several other) setting alone will make it almost impossible to steer or hit a doorway properly. This and a few other settings are why you think you actually need more profiles.
This is why I asked question 1 which you still didnt answer.
Users browsing this forum: ex-Gooserider and 28 guests
