Burgerman wrote:Where are you?
From sunrise its not cheap Around 1k?
From permobil its the same thing but
From PG drives direct not sure. How does your mobility gear get funded?
You follow the exact list of things that I keep on posting. Which you always ignore, and then think you can fix it with programming.
1. YOUR CHAIR is not a stable platform. It behaves as an unstable platform. The faster you go the more the chair WANTS to change turn.
A REAR DRIVE chair IS a stable platform. The faster it goes the more it wants to go straight.
So even without all the other things I suggested this will cure most your problem.
2. You dont have the hand or control capability or joystick skills to properly control a chair. So you NEED a different input device, possibly a longer joystick handle for e.g.
This too will probably cure your problem. Or make things MUCH better. This requires a different joystick.
3. You need lower geared (slower speed) motors. Because this will cure the stability issue at speed, but it also means that they will be better able to control the steering of your chair due to their higher torque. So turn speeds will be similar at all speeds.
This alone will probably cure much of the problem.
4. Your seating is all wrong!
5. Your joystick position and mount is all wrong.
6 You will never have any semblence of control with your legs waving around in mid air.
Sort out ALL of the above. Then your problems will be gone. You have everything possible wrong. No amount of programming will help unless you first sort out all of the above.
So as usual, here we go all over again.
Burgerman wrote:Also watch this, this is carlo joystick. https://www.wheelchairdriver.com/board/ ... p?id=19890
Its longer and so less sensitive and carlo needs that and so do you. But thats not ALL you need if you want better control and directional stability at speed.
Burgerman wrote:3rd time. 2nd thread. #
What is it that you think that this actually does?
Burgerman wrote:The reason I ask is because I do not think you know what it does. It will not help you. If you knew what it did exactly and set it correctly you would know this.
At low speeds it has no efect.
At high speed ,with low settings as soon as I move the joystich the chair skids
by raising the settings nothing happens.
why?
the groove has the same alectronics as the q700m
13km/ h 4pole motors120A control unit
reclining and tilting footrest all electrically adjustable joystich lcd without paddle buttons
i will take it back to understand the difference of driving
Users browsing this forum: LROBBINS and 97 guests
