I will replace the engine if necessary. lolBurgerman wrote:Its a mystery. Its PERMOBILS ICS.
Thanks for the information Flagimax! I went backFlagmax wrote:Just googling, it seem the main/master controller Cannot communicate on the LIN bus with the module for the standing feature. So it needs to be plugged in or if possible disabled in software by dealer. Its likely part of the actuator if it has 3 wires. To emulate this module is not an easy matter as you would have to capture the packets and play them back. So try plug the actuator in. Then maybe you could separate the module out of the actuator. You also will likely have to bypass the limit switches so the module doesn't freaks out and reports a different error.
Burgerman wrote:I'm confused. Which module have you added back in? And plugged it into what?
Marcelo wrote:Burgerman wrote:I'm confused. Which module have you added back in? And plugged it into what?
Hello Burguerman, in the actuator motor there is a mini module. I separated the engine module and came back with only it, understand?
I removed everything friend, I got rid of about 25 pounds and everything is fine, the error has not appeared anymore. Thank you brow!rover220 wrote:you need to uninstall the actuator in wheelchair builder.
https://www.youtube.com/watch?v=imjbSa3vUAA&t=478sFlagmax wrote:Just googling, it seem the main/master controller Cannot communicate on the LIN bus with the module for the standing feature. So it needs to be plugged in or if possible disabled in software by dealer. Its likely part of the actuator if it has 3 wires. To emulate this module is not an easy matter as you would have to capture the packets and play them back. So try plug the actuator in. Then maybe you could separate the module out of the actuator. You also will likely have to bypass the limit switches so the module doesn't freaks out and reports a different error.
https://www.youtube.com/watch?v=imjbSa3vUAA&t=478srover220 wrote:you need to uninstall the actuator in wheelchair builder.
Marcelo wrote:Marcelo wrote:Burgerman wrote:I'm confused. Which module have you added back in? And plugged it into what?
I eliminated the weight of the motor and actuator.
slomobile wrote:Nice!
I did a similar thing with my F3. Removed the legrest actuator because I didn't need it, but had to take the green controller board off the back of the actuator motor and plug it in to make the error go away. It is a LIN bus node for ICS. Everything works as expected without it, the blinking error just gets annoying.
Marcello, if you ever want to sell the standing parts you don't need, I want them. Especially the chest bolster mounts that go on the armrests.
Thankslomobile wrote:I live in Memphis Tennessee USA. Maybe hold onto your parts until you are absolutely sure you won't need them. Front anti tip wheels aren't used very often, but sometimes they save you and you might want them back on. Sudden stops downhill, going over curbs, bridging over some potholes. Glad you are getting your chair the way you like it!
Users browsing this forum: No registered users and 87 guests
