Burgerman wrote:You can have 2 functions for each button. How many do you have now? Can be 0, 1, or 2...
You can also swap functions on the profile and other buttons and paddles. And choose a time for a long press for a 2nd function.
I use this for e.g to disable the indicators and the hazard lights. Those get pressed and are a pain to turn off. And use the buttons for trip distance reset, and other functions. You could use the LIGHTS button to lower the seat lift with a long press (2 seconds) for e.g. I think. I never tried that! But it appears possible. So no menu needed.
Burgerman wrote:Profile is the PROFILE BUTTON. Its in the centre?
The SPEED PADDLE is on the right. (Speed up, speed down). Now you CAN program that to do other things, but you need that to change speed as you drive?
The profile button shouldnt really be needed as you drive. But the SPEED PADDLE is.
The profile button will display whatever you tell it. You can choose in the menu. It can only show profiles you have ENABLED and as many as you want. You can program that to be momentary and scroll through all profiles, or a long pres to choose a selected profile. Or program it to do something competely different.
Burgerman wrote:No.
Burgerman wrote:No matter how many times you ask the same question its still NO. Its an ON/OFF switch! If it did other stuff instead how will you turn it on? Or off? So no.
Its an ON/OFF switch/button. Its the only one that you cannot change. Or add extra functions. So no.
QUESTION. Which you wont answer. WHY do you want it to change profiles?
Users browsing this forum: Bing [Bot], Jay_x and 36 guests
