Disassembly manual
Disassembly manual
Postby martin007 » 08 Sep 2023, 17:33
Hello.
I'm looking for something similar to this. looking for a Sunrise F35 R2 disassembly manual.
In PDF format.
Re: Disassembly manual
Postby Burgerman » 08 Sep 2023, 17:37
https://www.sunrisemedical.eu/powered-w ... irs/f35-r2
Scroll down the page. Look carefully. Theres all the instructions, manuals and a PARTS link to sunparts. Sign in.
Postby martin007 » 08 Sep 2023, 17:44
OK.
Thanks.
Postby martin007 » 08 Sep 2023, 17:49
What exactly is the model of your powerchair?
Salsa R2 / M2 HD
SALSA R2/ SALSA M2
Salsa M HD
Postby Burgerman » 08 Sep 2023, 18:39
Which one?
I have a modified custom Salsa R2. And a modified but no custom parts other that tyres and wheels Q700 R.
Postby martin007 » 21 Mar 2024, 01:32
Burgerman wrote:https://www.sunrisemedical.eu/powered-wheelchairs/quickie/power-wheelchairs/f35-r2
Now I can't access the link.
Can you guys access?
Postby woodygb » 21 Mar 2024, 01:47
NO ....404 Page error
Postby Burgerman » 21 Mar 2024, 03:53
Postby martin007 » 21 Mar 2024, 18:51
Burgerman wrote:https://eparts.sunrisemedical.eu/indexic.php/m/spc/index/catalog/Sunrise_IC/path/%2C0%2C1%2C13730
I already knew him that way.
Thanks.
Postby Burgerman » 22 Mar 2024, 00:04
Thres nothing really on a powerchair that is technical enough to need a manual. I have stripped and rebuilt many. Taken every part that can be taken apart to bits. So I could replace worn, repaint any scratched or corroded, replaced electronics, beefed up looms, replaced bolts and bearings with better stainless ones and greased everthing. There was never any reason to need a set of instruction. Its all very basic stuff. If you ever orked on cars or anything needing tools etc then its all self explanitory.
But you do need the sunrise site or whatever manufacturers site site or PD file matches it. To get the part numbers of components that are not generic. Theres not that many that you will need though. The stuff that wears out like tyres, bearings, bolts, wirin stuff and even the control systems as well as many plugs, clips, fittings, etc are not made by the chair manufactures. And can be found cheaper elsewhere. And while they do make frames and big metal parts like the bits that make up backrests and seating stuff those tend never to wear out. At worst, they need a trip to a bead blaster and a coat of paint or powder coating. Things like motors and broken plastic moulded parts are the main exception. And possibly upholstery and arms/tops.
Postby martin007 » 24 Mar 2024, 20:02
I have a lot of mechanical tools.
Hand tools and power tools.
I grew up in a rural area surrounded by machines and animals.
I lack physical strength, but I have more than enough skill and imagination.
In any case, a disassembly manual is always useful.
"Information is power."
Postby Burgerman » 25 Mar 2024, 01:41
Yes. But you dont have one. But its not really a problem. Can you still get parts?
Users browsing this forum: AgGuy, mentado020477 and 32 guests
