You can program any of the buttons on the CJSM2 joystick to do a short or long press. So ignoring you new button, you could just program any of your existing rubber built in buttons to do seating functions directly. So for e.g. press the HAZARD or INDICATOR on a long press and short press to do your tilt/lift and no menu digging required. Or set latched.
rover220 wrote:If you use a stereo to mono splitter you can connect 2 buttons to the socket and control 2 functions.
Burgerman wrote:Can you set it latched so that one button can do both up and down? Must say I have never plugged anything into one of those connetions.
You can program any of the buttons on the CJSM2 joystick to do a short or long press. So ignoring you new button you could just program any of your existing buttons to do seating functiond directly. So press the HAZARD or INDICATOR on a long press to do your tilt/lift and no menu digging required.
11ydy wrote:A stereo plug is connected to two buttons, and short press and long press are respectively set to achieve four functions.
一个立体声插头接两个按钮,分别设置短按与长按实现四个功能
expresso wrote:Burgerman wrote:Can you set it latched so that one button can do both up and down? Must say I have never plugged anything into one of those connetions.
the JS is a Rnet from a permobil chair - i will try it latched first and see what it does -when i get a chance -
Burgerman wrote:expresso wrote:Burgerman wrote:Can you set it latched so that one button can do both up and down? Must say I have never plugged anything into one of those connetions.
Not r-net, permobil?
You probably cant map all the buttons like you can with r-net. Different firmware on permobil. So cant say what that will do. Probably be ignored. Works on mine though.
Burgerman wrote:Its not in their oem programmer from what I remember. Dont have it installed right now. I doubt the sunrise programming options will "stick" and will be ignored. And no button mapping in generic OEM at all. How do you do it?
Does it also depend on which permobil file you look at or edit?
Burgerman wrote:Fair enough. I got it to work. I used the permobil OEM and an M5 profile. NOW it shows the button mapping!
But unless you are talking about a different build option to the M5 I have here you get the exact same mapping options as sunrise OEM gives you?
Below is a comparison one of my chairs with Sunrise OEM. And an M5 with Permobils OEM.
How do I get to see any extra mapping options?
Also some cant work as there is 2 buttons missing on permobils own joystick.
Permobil have for more mapping options than sunrise.
Users browsing this forum: No registered users and 38 guests
