It's ONLY useful, when charging more than one pack simultaneously, OR you have battery packs which are NOT 8S.expresso wrote: …would it be worth to have one around - ,
shirley_hkg wrote:It's ONLY useful, when charging more than one pack simultaneously, OR you have battery packs which are NOT 8S.expresso wrote: …would it be worth to have one around - ,
Can you point me to the specs of the JST CONNECTOR ?
Adding an XH /XE 2.54 to the other end is OK.Burgerman wrote: The other end can have 9 pin or 10 pin XH idealy
shirley_hkg wrote: I'm planning to order them 1 metre long (with 22AWG silicone wires thickest it can gets.)
I have a balanced cable direct from the pack on my wheelchair that goes straight into the PL 8. I wanted a short balance cable extension cable, so the heavy-handed care workers don't break the PL 8. I wanted it short, 6 to 12 inches rather than 36 inches long, so it doesn't add too much land to the balance cable.shirley_hkg wrote:
I may be able to get someone to make a lot as small as 50.
I'm planning to order them 1 metre long (with 20awg wires thickest it can gets.)
Users browsing this forum: Burgerman, Qvickster, UnicornBurner, woodygb and 32 guests
