PL8 ordered!
Re: PL8 ordered!
Postby woodygb » 12 Feb 2024, 20:16
I am happy with NOT being able to screw things up! :)
Re: PL8 ordered!
Postby Burgerman » 12 Feb 2024, 20:43
Well if you want 4 decimal places, and averaging of data designed to make pretty graphs rather than accurate graphs then its all or nothing!
Probably easier/safer just to use a few of my presets and modify/adjust those to do whatever battery or cell you have.
Re: PL8 ordered!
Postby Khreat » 12 Feb 2024, 20:48
Burgerman, sorry the first pack I plan on trying is a 3x7s with ncr18650pf cells.
I'll look onto the power supply, but for lead, my pc1220 will have to do for now.
Khreat
Re: PL8 ordered!
Postby Burgerman » 12 Feb 2024, 22:10
Lithium ion cells?
OK.
For Lthium Ion, cells (phone, laptop, type chemistry with 4.2V charge).
SET CURRENT on charge and discharge to your prefered level. Usually 1/3rd to 1/2 pack capacity. All else inc cell count is automatic.
LiCo Charge lithium Ion USER AMPS.PS8
(3.19 KiB) Downloaded 2 times
Re: PL8 ordered!
Postby Khreat » 13 Feb 2024, 00:50
Thanks, it seams simpler that I had feared since you started mentioning it but happy to have support.
Khreat
Re: PL8 ordered!
Postby Burgerman » 13 Feb 2024, 00:56
All simple once familiar.
Re: PL8 ordered!
Postby expresso » 13 Feb 2024, 02:59
woodygb wrote:The "Cell Display" option does not exist.
thats correct on the one i am using right now - same as this - there is no option there
its fine with me - dosnt bother me that its not there - just to point it out - since it shows on yours -
i am fine with leaving it alone - less tinkering the better
Re: PL8 ordered!
Postby shirley_hkg » 13 Feb 2024, 04:08
Khreat wrote: For the power source? 2x75ah lucas sla, in series/parallel, whichever would be best ?
In series.
Higher volt / lower current is preferred.
Re: PL8 ordered!
Postby Burgerman » 13 Feb 2024, 17:39
My lithium ion 2S camera Z8 battery is being charged right now. It has a BMS in it. So is being charged without cell balancing. At 1A to 4.140v per cell, with fast terminaton. Or about 95% charged. I charge many things with the PL8... Got 2 more to do. If they were to be stored rather than used I would charge to 80%. Because then they will last 1000s of cycles rather than a few hundred.
Re: PL8 ordered!
Postby Burgerman » 13 Feb 2024, 18:06
Now its done! 95% as it will be used today and tomorrow.
Users browsing this forum: AgGuy and 67 guests
