snaker wrote: Compared to my current PL8, it sounds better. Charging with my current PL8, the cell volts are not balanced. I thought the cells aged. But charging with the new Shirley's PL8 cell volts are very balanced. So the cells have not aged, my current PL8 aged .
I encountered about half a dozen imperfect units so far , though they still be good to use.
halfway discharged LiFe should have all cell volts the same.
Burgerman wrote:How much is shipping? Would love a free faulty one..
Khreat wrote:Thanks..
I haven't got any ec5
Burgerman wrote:I encountered about half a dozen imperfect units so far , though they still be good to use.
Shirley. I asked this queston by PM and in at least 5 different threads. HOW are you measuring the PL8 read voltage?
Because you CANNOT see the voltage it actually reads unless you also enable the 4 digit decimal places. If you dont, then it squeezes all the voltages together, and averages them closer to make pretty graphs. And to disguise any bad calibration that will not affect the user.
So can you confirm that you do this below. If not then all the voltages you are reading are WRONG!!! 4 decimal places not only increases accuracy it also removes the false "squashed together" data. You MUST do this. If not the figures you see are nonsense!
Burgerman wrote:Busy here. Give me some time. What are the batteris?
shirley_hkg wrote:Khreat wrote:Thanks..
I included an EC5 male already.
expresso wrote:
Just reading this now - i checked my PL 8 i am using and it dosnt have an option to pick decimal count display etc,
i believe its 3.36v firmware -
Khreat wrote:Burgerman wrote:Busy here. Give me some time. What are the batteris?
For the power source? 2x75ah lucas sla, in series/parallel, whichever would be best? I don't think I'll be using higher current charging until I've got a mains supply.
Users browsing this forum: No registered users and 47 guests
