Yes. Except that the correct figure for a 90Ah lifepo4 would be 90Ah x 25.6V.
Fit an inverter to your chair and you have exactly the same thing.
Longest-Lasting 10-Year Lifespan with Anker's Proprietary InfiniPower™ Technology.
Marketing speak. LiFePO4 cells are easily good enogh for 10 years use. Unless they have BMS issues, uneven self discharge etc.
Rapid Recharge from 0 to 80% in 1 Hour via HyperFlash Technology.
Marketing speak. That means you can charge it at 1C. Thats quite low. And would need a powerful charger. You would need to charge at 90A and that means a lot more han you can get from a wall.
Power Up to 10 Devices At Once with 2300W and 10 Ports.
Means it has an AC inverter, that can drive up to 2300 watts worth maximum. Thats usually enough. Wont run say my 3KW fan heater or anything that adds up to 2300w or more.
It appears to have a 2048 Watt hour battery. We dont know if thats at 12, 24, 36, 48V or whatever. But it doesent make any difference which is why they use watt hours rather than Ah. 2048 watt is the battery total stored energy measurement.
So if that was say a 25.6V 8S LiFePo4 battery pack it would be an 80Ah battery. How do I know? Because 2048 watts divided by 25.6V = 80Ah.
Its a bit steep £££$$$ for a 2048 watt hour pack.
As an approximate comparison, the 230Ah packs that seem quite common around here at around 1k cost, are a massive 230 x 25.6 = 5,888 watt hours in comparison! Thats almost 3x bigger.
