If you intend designing your own control system then best of luck as its extremely complex if you intend it to be in any way safe and controllable.
Burgerman wrote:The problem there is that it will take a couple of years to proprly develop a control system befre they can start of the project they are really interested in. And its just easier to use say a complete r-net powerchair with an IO unit or a Omni device designed to accept external dc voltage swing input for alternate control Since that already exists with a decade of development work aleady done.
I'll buy that, and even brain controlled speech as long as there's a backup for when it isn't working. BUT a brain-controlled wheelchair (or any wheelchair control that depends on a PC operating system, or, heaven forbid, the cloud ---- NO. The safety issues with that are scary. Consider faults in two circumstances: going when you should be stopped (e.g. waiting for traffic to clear before crossing a street), and stopping when you should be going (e.g. half way across an intersection).Brain controlled doors, lights, heating, typing, etc would all be marvelous!
LROBBINS wrote:At a minimum, if using a robotics controller one will have to program motor compensation or a constant speed algorithm and most likely some kind of acceleration-priority or acceleration mixing routine so that when changing both heading and speed you get predictable heading.
Burgerman wrote:Changing he subject very slightly, I am my own "cloud". Cloud is not needed.
I completely agree with this, I'm amazed how many people use cloud based systems in home automation etc. My Home Assistant install does not require any cloud access though I can use a VPN to access it whilst away from home. You would have to be a bit soft in the head to rely on any system that needs on an internet connection to function without a local option ( in my opinion ). I'm even more concerned about the headlong dash to connect cars to the cloud, it's positively dystopian and as for drive by wire, don't get me started , pass my tin hat.
Burgerman wrote:IAll my computers are set up with wake.
There is NO SUCH THING as "CLOUD"!
Phones have about 250GB of storage anyway.
I should let my students interact with wheelchair users and professionals who tailor wheelchairs to the user's needs.
Burgerman wrote:I should let my students interact with wheelchair users and professionals who tailor wheelchairs to the user's needs.
I dont know who gavin is but I suspect the "professionals" and end users will get you nowhere fast.
Users browsing this forum: AgGuy and 65 guests
