martin007 wrote:Temperature Compensation is 0.005V / ºC
Burgerman wrote:Anywhere from 14.4 to 14.7V is OK for AGM. At 20C. If its warmer as spain is its best to err on the lower side. So if the battery is hot in summer charge at a bit less. Maybe if its 30C drop it to 14.2V or the current will never drop to a low figure. With your charger you should set it to go to float at say 300mA. (0.3A) and then float.
Burgerman wrote:Another thing to consider is that battery ageing is in direct proportion to temperature too. And its very severe! A few degrees cooler = double the calender life. So find somewhere cool to store it.
Burgerman wrote:Not keeping them topped up 100% and charging to 101% after discharge also kills them faster. (Lead).
Not chargng straight away after use too... (lead)
Burgerman wrote:Develop t?
Batteries die from many things.
Wheelchair batteries generally die from bad use and bad charging practices.
A battery at a basic level is all lead plates. These are lead grids, a lead "frame" into which is pasted finely ground up lead paste.
Each place is submerged in a water and sulfuric acid bath.
When it is DISCHARGED the acid in the electrolyte is split into lead sulfate (which coats every one of the lead particles deep inside the plates) and lead dioxide on the opposite plate. And the deeper it is discharged the heavier this sulfate coating is. It can and does cause the plates to expand and can push out and damage the pasted lead particles too. If discharged deeply. Now, as you recharge this is all reversed. The lead sulfate is the important bit, this is returned back to the electrolyte from where it came. The problem here is many fold!
Dont wait! Warmth, and time, causes this lead sulfate to form large crystals over time. Once it has, it is inside the pasted material deep inside the plates displacing the lead particles. Worse these larger crystals no longer conduct electricity. So can NEVER then be reversed. So its important to do several things.
1. Recharge as soon as it is possible to do so. So that 99.999% can be returned to the electrolyte.
2. Dont store a battery in any state other than 101% charged. If its 99% charged and you leave it this way then you just lost 1% of its capacity for good.
3. Make sure that you COMPLETE a full 101 % charge at least every 7 days. That doesent mean charge with a mobility charger till it goes green. Thats NOT 100% or even close to it. It takes a full 10 or so hours to charge a lead battery with a correctly configured charger. And at LEAST 16 to 20 with a typical mobility charger. Regardless of its green light coming on! It needs a long time AFTER this at float. Because the mobility charger stops the CV stage far, far too soon.
4. You need the right voltage. A few tenths of a volt too high will reduce a gel battery cycle life by 60%. A few tenths too low will likewise half the life of a good AGM like odyssey. So be sure you know. And set correctly. Mobility chargers do all sorts of incorrect things here! I dont use them.
That's one thing I've noticed about these Victron chargers, they don't stay in float very long.
Typical is approx 10 to 15mA when off. Or practically nothing. Just eNough to cause battery degradation if you dont do a proper charge every 2 weeks. (will cause sulfation otherwise).
What are you measuring this with?
So likely the victron is stopping the CV stage too soon. Because you havent yet took charge...
I do have one question. I am a light user on days I stay home. I have MK Gel batteries. Currently do 2 hours of CV at 28.2 which gives approx. 2.5Ah and then it does 8 hours at 27.6 to get the final 0.5Ah so 3Ah in total.
I use much more when I venture outside and increase the CV duration. Is it possible to overdo the CV on my light 3Ah days? Could I set the CV to 8 hours and lower the float without issue if I wanted? Considering lowering the float to 27.2 and increase the CV to 4 hours on the light days for just increase work comes calling.
Does it drop to almost zero current? It should or that 2 hours isnt long enough. Say 70 to 100mA?
Users browsing this forum: shirley_hkg, woodygb and 60 guests
