Page 1 of 1
PPONE Programmer For VR2 Controller
Posted:
21 Jan 2024, 21:21
by martin007
Has anyone used it?
Is it really useful?
Re: PPONE Programmer For VR2 Controller
Posted:
21 Jan 2024, 21:27
Well if its OEM it is. If not then better to let woody make you a cable and get a OEM ar Factory programmer on your PC.
Posted:
21 Jan 2024, 21:33
by martin007
How is it different from a R-net Dongle OEM (B)?
Posted:
21 Jan 2024, 21:37
Its a completely different system. Like downloading mac software for your PC. Or a Buick V8 to fit to your ford car. Both these things can actually be done (I did the V8 one) but the VR2 controller cant configure an R-Net system or the opposite way in any way!
VR2 is a very basic not very configurable simple system. R-Net is the opposite.
Posted:
21 Jan 2024, 21:46
by martin007
It isn't possible to configure a VR2 controller with an OEM RNET Dongle (B)?
Posted:
21 Jan 2024, 22:51
No. Not to mention wrong bus cable type. So you cant fit it in the loom.
Posted:
21 Jan 2024, 22:54
by martin007
OK.
Burgerman wrote:Well if its OEM it is. If not then better to let woody make you a cable and get a OEM ar Factory programmer on your PC.
Is it possible to connect the VR2 with direct cable to a PC and configure it?
Posted:
21 Jan 2024, 22:54
Posted:
21 Jan 2024, 22:55
by martin007
What software is used?
Posted:
21 Jan 2024, 22:57
Dont worry about that I have a copy or 4 and various versions. See woodygb for cable.
Software is at least 10x more basic and simple than r-net which has well over 1000 settings and configuration options.
Posted:
21 Jan 2024, 22:59
by martin007
Are you telling me that with a cable and a software you do the same thing as with a €400 programmer?
Posted:
21 Jan 2024, 23:00
No. It does more. Because the hand held one is lkely a dealer A level one. Or at best its a B OEM one. We have the manufacturer version a C version...
Posted:
21 Jan 2024, 23:05
by martin007
Would it also work for a joystick Pilot?
Posted:
21 Jan 2024, 23:07
No. Too old.
Works with pilot plus.
Posted:
21 Jan 2024, 23:09
And VSI, some scooters etc.
Posted:
21 Jan 2024, 23:09
by martin007
Besides VR2 which others are Pilot Plus?
Posted:
21 Jan 2024, 23:10
• VSI control systems.
• PILOT+ Control Systems.
• S-Drive Control Systems.
• Egis Control Systems.
• VR2 Control Systems.
Posted:
21 Jan 2024, 23:16
by martin007
Interesting...
Are there only two RNET versions?
Posted:
21 Jan 2024, 23:36
Well I have 4 different ones on my bench so no at least 4! All are plug and play, no reprogramming.
Theres also 2 different CJSM2 ones. One has infra red to control your TVs and stuff. The other has additional BT to control devices...
And theres a colour but older all plastic one, does the same as the CJSM2 but cheaper and the one you show above, a few special ones like the HD versions, and permobil make a crappier one with 2 buttons missing and a smaller darker screen but technically thats not really r-net but it still works.
Posted:
21 Jan 2024, 23:57
by martin007
Posted:
22 Jan 2024, 00:15
There are R-net stability modules, seating angle modules, gyro modules, IO modules, bus splitters, 5 standard seating modules with different capabilities, an SM module that works only with the economy 90L power module, an advanced positional and memory seating module, a lighting module, and as well as a lot of joystick modules and switch and control additions. Oh and a attendant module remote as well as an omni system for alternative controls. And an HD joystic option. And 4 different output power modules.
And then a programmer with approx 1,200 inter related settings and options that alow an awful lot of complex configuration. Its all plug and play and all fully programmable and the best system out there right now.
Posted:
28 Jan 2024, 19:36
by martin007
Burgerman wrote:No. It does more. Because the hand held one is lkely a dealer A level one. Or at best its a B OEM one. We have the manufacturer version a C version...
This?
https://www.cw-industrial.com/en-gb/pro ... programmer
Posted:
28 Jan 2024, 19:56
Mobility - PC Programmer
Software is available which allows programming of the control system from a PC. Three versions are available - Dealer version, OEM version and the Manufacturing version.
Yes that. Does VS1 2 and new VR2.
The older versions mobiliy programmers do things like
• VSI older control systems. NOT VSI-2
• VR2 Control Systems. Not new version.
Posted:
28 Jan 2024, 19:58
by martin007
OK.
Posted:
19 Mar 2024, 07:30
by FelipeOliveira
Burgerman wrote:Dont worry about that I have a copy or 4 and various versions. See woodygb for cable.
Good morning Burgerman
What is the newest version of PGDT software?
If so, could you send it to me?
I can't access NEW VR2
Felipe Oliveira -BR
Posted:
19 Mar 2024, 07:31
by FelipeOliveira
Felipe Oliveira -BR
Posted:
19 Mar 2024, 15:26
PM me and I will give you a link.
