PL8
PL8
Postby Burgerman » 04 Feb 2024, 17:33
4mm contacts. I have a bunch of them. Some were very unsteady and read fluctuating readings. Esp on small hobby packs. Switch cleaner not doing the trick.
So I ordered a 4mm wire brush. Total transformation. Those 4mm connectors on the PL8 get dirty!
Like this one.
https://www.ebay.co.uk/itm/145472812214
Should you have a simlar issue reading resistance or fluctuating readings. Easy fix. Quick squirt of switch cleaner and hit it with the brush! Graphs are all dead smooth and precise again.
Re: PL8
Postby martin007 » 04 Feb 2024, 18:22
A rolled up piece of sandpaper may be more effective...
Re: PL8
Postby Burgerman » 04 Feb 2024, 18:26
Or worse! This is cleaner and easy. Sandpaper may work too if you reach the right parts inside.
Re: PL8
Postby martin007 » 04 Feb 2024, 18:35
A thin sandpaper can work.
Re: PL8
Postby Khreat » 11 Feb 2024, 13:39
Burgerman, are the bristles stainless? I ordered some from a different supplier and only the handle was stainless when they t7rned up. Not aggressive enough for some of the manky connectors I have to clean and emery is too messy and fiddly.
Khreat
Re: PL8
Postby Burgerman » 11 Feb 2024, 18:54
Users browsing this forum: LROBBINS and 78 guests
