Burgerman wrote:A more interesting question might be how long do your motors last...
Raro wrote:How many years do your batteries last? In 2023 I changed the MK 73ah batteries for the first time in my chair purchased in 2008..
In my opinion, even if you don't use the chairs, it doesn't mean that the batteries won't run out. I highly doubt that others will last the same for me.
martin007 wrote:Any user with a minimum of experience can tell you that the only way for a battery to last 15 years is to use them very little.
My first set of MK batteries lasted me over 20 years.
Burgerman wrote:They never stop "working" as such.
Burgerman wrote:My first set of MK batteries lasted me over 20 years.
They may have "lasted" 20 years. They were end of useful service life long long before that!
They are, according to the manufacturer at end of useful life, and down in capacity by 20% after 10 years float life when used as a backup battery. Thats as long as they can last. In float use. And down by 20% would be very noticible to many users inc me.
So no way on earth that a 20 year old battery - even if charged CORRECTLY which they seldom are, certainly not with a mobility charger - is anything other than a doorstop for at least 15 of those years.
Burgerman wrote: The time it makes "financial" sense to change a battery is when it affects you
Out of curiosity, how many kilometers can you do on a normal day?
Are you still using gel batteries? How many charging cycles will the batteries last in optimal conditions, charging them correctly for 300 cycles according to the graph?
I would encourage you to post a post telling what is the correct way to charge the batteries and what to use to do so.
Burgerman wrote: About 1/5 of all posts on this forum from decades ago do exactly this! There is no single, simple answer that works for everyone.
Users browsing this forum: acid_coke and 56 guests
