Bit settings changed but when showing motor company they daid:
The motors have specifications about the output torque and speed, based on input voltage and current. The problem is most probably on the input side, so motor controller.
Can you measure the inputs; current, voltage?
Any ideas what and how to do that setup?
Chair is etac e880 with rnet system control etc.
Burgerman wrote:Bit settings changed but when showing motor company they daid:
What does this mean?The motors have specifications about the output torque and speed, based on input voltage and current. The problem is most probably on the input side, so motor controller.
Very easy.
Plug in the programmer and look at the real time motor current as you use the chair and motor voltage (ignore battery voltage and battery current) and do them a screen shot. M1 and M2.
See below:
I got told not to do that by motor company.
The screenshots showed m1 and M2 having quite big differences between current and voltage. Does that not show motor Co issue with LH motor? As was straightforward so should be almost equal.
As lh stops but rh spins is there not a torque setting or something to adjust to match?
Can't lift chair up.
What can u do?
It doesn't make it up vehicle wheelchair ramp due to issue currently.
I have Kolector swissdrive brand new motors. The lh side one lacks power / torque to even make it up a wheelchair ramp. The rh has lots of power. They were swapped out from old motors that worked fine till other issue.
Right now your controller is doing everything correctly.
That video shows me nothing, what am I supposed to be seeing?
Both sides, both motors are being sent the same voltage. It went straight before right?
So if anything is different now then it is nothing to do with the controller or its programming. All I can see is that you are trying to get a small wheel to climb up a curb that is a bit too high. It hits the curb and stops or skids depending on traction.
Question. Does it dive in straight lines on a flat surface?
Users browsing this forum: No registered users and 17 guests
